Suspension issues?
nklomsue
Navy
corona
2022 Bronco sport Big Bend sways right after acceleration and after pedal is released. Feels as if floating to the right then corrects. I have checked for loose suspension, balanced wheels and had alignment done yet it still occurs.
Sounds like some torque steer going on, which could be normal for that vehicle
nklomsue
Navy
corona
Just odd because it wasn’t like that before
Are you feeling this in the steering wheel first or seat of the pants? Torque steer is typically felt first in the steering wheel.
nklomsue
Navy
corona
Feel in in the whole vehicle for a brief second then it corrects
I just recently replaced my OE tires that wore unevenly--inside tread wore faster than outside--in the last 5k-10k miles. Along with new tires, I had the alignment checked and discovered the front alignment was set toe out, that is the left tire was pointing slightly to the left, and the right tire was pointing slightly to the right. Up to now my car was always a bit squirrely under hard acceleration, requiring a firm touch on the wheel to keep it going straight. I assumed this was related to high power and a relatively short wheelbase. After the new tires and alignment the car tracks straight under acceleration. I don't know for sure if it was the tires or the alignment that fixed the issue, but I suspect it had more to do with alignment.
So, all of that was to say have your alignment checked. It can change over time.
Dannyp56
Danny
Payson, AZ
2024 Ford Bronco Sport
I had a problem similar to this and found out the lane keeping assist was turned on. I didn't even know where the button was.
