Sputtering and no acceleration
rltotten
Randal
Wyoming
2025 RAV4, 2018 Highlander, 2013 Victory
I had similar issue with my 2013 Escape. I replaced the high pressure sensor and it did not fix the problem. I then replaced the low pressure sensor and it worked perfectly thereafter.
Thanks for the input!
rltotten
Randal
Wyoming
I like this technician. Very clear and detailed description of the work they did. And, they seem to have solved a very strange problem with an inexpensive part rather than a whole new engine.
@rltotten you probably should redact your personal info on the invoice...never know what unsavory types are reading these forums!
Thanks! I cropped the repair invoice!
Thanks, makes sense now … Fuse 8 referred to is a circuit breaker… GU5Z-14526-BAE Fuse Junction. Panel Assy - Fuse Junction. Circuit Breaker Assy. and the DTCs relate to the issues you listed in Post #1.
I don’t have the wiring diagram for the Bronco Sport so was unable to find where that circuit breaker is located
It seems unusual to me that this circuit breaker would trip (fail) but I’m just making a guess on that. Let’s hope it doesn’t occur again.
Makes a whole lot better sense! I never heard of a fuse failing unless it was blown.
But a relay can fail.
