Back when radios had physical buttons for the radio preset, you could perform a Speaker walk-around test.
Whereby it would play static or a source audio on each speaker. The sound would "walk around" each of the speakers. I am not sure what this would accomplish, but previously if you hit a specific preset during this test, it would open up certain troubleshooting menus. Linked below is a write-up for 2008 Ford Escape for a better explanation.
Typical information available
Link: https://www.escape-city.com/viewtopic.php?f=8&t=28946&start=10
I found a similar test in the 2021 Bronco Sport Service DVD.
Bezel Diagnostics
Check
NOTE: If there is a concern with one of the following components and Bezel Diagnostics cannot be accessed, obtain the module part number by referencing the label attached to the module.
- Audio DTC
- Part Numbers of associated modules
- Version number associated modules
- Speaker tests
- Screen Tests
- Radio signal tests
Bezel Diagnostics
Check
- Inoperative ACM
- Inoperative (blank or does not power on) display unit (non-touchscreen display or touchscreen display)
- Inoperative FCIM or radio control panel
- Inoperative steering wheel switch
- Ignition ON.
- Operate the audio system in AM / FM mode.
NOTE: It may take up to 20 seconds for the system to enter bezel diagnostics mode.
For vehicles with SYNCFor vehicles with a CD player integrated into the ACM , simultaneously press and hold the FCIMEJECT and the SEEK UP buttons until the bezel diagnostics mode is entered. If supported, the Speaker Walk-Around Test begins and the display indicates each speaker as it is tested. For vehicles without CD player integrated into the ACM , simultaneously press and hold the steering wheel SEEK UP and the FCIM SEEK UP buttons until the bezel diagnostics mode is entered. If supported, the Speaker Walk-Around Test begins and the display indicates each speaker as it is tested. For vehicles without SYNCSimultaneously press and hold the FCIM POWER ON and the SEEK DOWN buttons until the bezel diagnostics mode is entered. If supported, the Speaker Walk-Around Test begins and the display indicates each speaker as it is tested.
- NOTE: Some selections listed below may not be available for the vehicle being tested. Selections are vehicle and option dependent.
Once the Speaker Walk-Around Test (All Speaker Test) is complete, the following information is available:
Vehicles with SYNC
Menu Submenu APIM Diagnostics Part NumbersSoftware Versions Configuration Status Location Information Tones Test Touchscreen Activation Test Display Test Pattern RGB Pixel Test IVSU Versions Exit Diagnostics AHU Diagnostics (AHU refers to the ACM )AHU Part Numbers (also displays Sirius ESN )Radio Signal Strength Speaker Walk-Around Test Active (if not equipped with DSP ) Exit Diagnostics DSP DiagnosticsDSP Part NumbersSpeaker Walk-Around Test Active Exit Diagnostics EFP Diagnostics (EFP refers to the FCIM that communicates on the CAN )EFP Part NumbersExit Diagnostics ICP Diagnostics (ICP refers to the radio control panel/ FCIM that communicates on the LIN )ICP Part NumbersExit Diagnostics SDM Diagnostics (SDM refers to the display unit)SDM Part NumbersExit Diagnostics
Vehicles without SYNC
Menu Submenu CHR Diagnostics (CHR refers to the ACM ) CHR Part Numbers / Sirius ESNRadio Signal Strength Speaker Walk-Around Test Exit Diagnostics
- To exit the bezel diagnostics, press the on/off button or select "Exit Diagnostics.”
