- First Name
- Mark
- Joined
- Oct 30, 2021
- Threads
- 119
- Messages
- 6,733
- Reaction score
- 13,156
- Location
- St. Jacob, IL
- Vehicle(s)
- 2021 Badlands | 2020 Escape
- Thread starter
- #1
The wife's 2020 Escape and our new Bronco Sport both have electronic parking brakes, which is a first for me. Turns out you cannot SHOULD NOT service the rear brakes unless you set the parking brake into maintenance mode. Fortunately, you do not need any fancy tools or diagnostic gear to do it.
NOTE: Both of our vehicles have push-button start. I have tested this procedure on both and it works. This procedure should work for cars that require a key to start, but I do not have a car I can test it on. If your car requires a key and you try out this procedure please let everyone know if it works.
To set maintenance mode:
To exit maintenance mode:
EDIT: 69cuda340s pointed out below that you actually CAN take the rear brakes apart without putting the parking brake into maintenance mode, but it will likely not end well.
- Turn on accessory power without starting.
- Depress and hold the accelerator pedal and press (not pull) the parking brake switch simultaneously.
- While still holding both, turn accessory power off, then back on.
- After a few seconds the system will chime and display a parking brake maintenance mode notification on the instrument panel.
- Release the accelerator pedal and parking brake switch.
- Turn off accessory power. The system will display another notification that the system is in brake maintenance mode.
- Turn on accessory power without starting. The system will display a notification that it is set to parking brake maintenance mode.
- Depress and hold the accelerator pedal and pull (not press) the parking brake switch simultaneously. The system will chime and display a warning that you are in parking brake maintenance mode.
- After a few seconds the system will display a notification that brake mode is normal.
- Turn off accessory power. You should NOT see a parking brake maintenance mode notification.
