V8 Yankee
Harold
Miami
21 Bronco Sport
thanks for the great info on parts.
I was just going to replace the backup light to be brighter. But I thought if I was taking out of the tail light assemblies to do this, I might as well replace the other lights consider there is a split second difference for the LED to light up quicker.
Good morning, when I click on the tail light link you posted I get a "this part does not fit a 2021 Bronco Sport". It's the right PN, looks correct too. Yesterday my right side Alla tail light gave up, got the hyper flash warning. It lasted 10 months so I'm leary of buying another Alla. Because it's still under warrenty I'll wait and see what Alla says, maybe they have upgraded the light. Good luck on yours, keep the forum updated on how yours works
I hate being behind vehicles with LED tail lights.
Some vehicles are particularly annoying because the tail lights are at eye level and the LEDs are just way to bright.
I think someone should start a class action lawsuit, I think the lights are dangerous, some seem almost as bright as headlights.
LazyDirtFarmer
Chicagoland, NE Illinois
2022 Bronco Sport, 2014 Escape, 2022 Tri Glide
I think @WildFord was referncing the links in my earlier post... Yes, Amazon says on the Red Taillamps "Part does not fit" but that is not true... I have these on my BS, with no hyperflash and no flicker. Note: The Red 3157 LEDs for the Taillights have cooling fans in them... If it's quiet, you can hear them spin-up when you apply the Brake... I like it, but it may annoy some.
V8 Yankee
Harold
Miami
21 Bronco Sport
I don't think fan noise will bother me, my hearing is not quite what it used to be. Hopefully Alla will replace the two older versions I have under the warranty. With one already shot the other one is probably not far behind. I have the original ones back in now and I have to say they are good. I put LEDs in the backup and turn signal slots and they are holding up good. I'll know more tomorrow if Alla responds to my email. More to follow.
WildFord
Los Angeles
'22 BS BL
sure I will update after a little bit of time.
I bought those lights based on your old message. maybe I didn't keep up the thread...did you post some newer parts to buy instead?
I have no issue right now on the bulbs. or at least I haven't noticed....but it is hard to know when it is back of your own car. I don't see it :)
V8 Yankee
Harold
Miami
21 Bronco Sport
Hello, not sure your question is for me. Concerning the LEDs, if Alla replaces my 10 month old Brake LEDs I'll go with it. Sounds like they've been upgraded with a fan, heat probably killed my last one. Ill even pay the extra cost if any. The built in fan should increase the life. I'll for sure keep the original bulbs as back up for all LEDs.
WildFord
Los Angeles
'22 BS BL
I checked my order. I have the new 3157 with the fan LED bulb.
let's hope Alla replace you with this latest one.
speaking of hyper flash, we will see that on our dash indicator?
V8 Yankee
Harold
Miami
21 Bronco Sport
Yes, at least on my 21. At first I thought it was the Blinker LED. Turned out to be the Brake LED.
coolsan
Santiago
Mexico City
Bronco Sport OB
Hey there!
Just swaped turn and reverse bulbs for LEDs, Alla and Philips respectively.
Love the looks and for now no problems!
