Removing sticker from side, the triangular one
'Cause
'Cause
Ken
Northern Arizona
2023 Ford Bronco Sport
I'm actually way west as in Lake Havasu.
I used the good old az sun on a 120 degree day, came right off along with the sport on the back.
Hadn't thought about the SPORT...
Robink
Robin
Utah
Ford Bronco sport
From what I understand I can take the "sport" off the back the same way? I used a hair dryer with the badges. Yes?
Oso Fell
Oso
NYC
23 Bronco Sport
I particularly dislike the OBX decal that they come with. So I replaced mine with this. However I also do like the no-badge look too
Ford Bronco Sport Removing sticker from side,  the triangular one IMG_1847
Love the badge. Question. Did you install the body side moldings? If so, was it difficult. Any advice? I’m going to install them tomorrow.
Hot Rod Mike
Rocklin Ca.
Gladiator , Wrangler , Bronco
Has anyone removed the 'factory' sticker from the side, the triangular one such as: BIG BENDS, OUTER BANKS...
Is it just a 'sticker' that could be heated with a hot air gun and peeled off?
Just would prefer a clean look to the side.
Ford Bronco Sport Removing sticker from side,  the triangular one AAa23BRONCO.JPG
Hammer and a chisel
missOutsyder
KT
Kamloops BC
Sorry, I can’t help you, I asked my ceramic coating guy to install them along with the fender flares, prior to ceramicking everything. He did it for an extra $50. He did eff up on the badges though as he installed the new badges prior to the mouldings and because they were in the same place as the stock badges he took off, they got in the way. So he removed the badges and I had to order a new set as they bent. But he paid for them. Good luck! I think the mouldings look brilliant.
Oso Fell
Oso
NYC
23 Bronco Sport
Thanks!
Mwittke5857
Elma, NY
2021 Bronco
Mine were weather-worn and I thought the "Sport 4X4" decals on the rear quarters would look better. I just (slightly) heated them with a heat gun and they pealed right off. I used a 30% solution of 90 alcohol/water to remove any glue left behind
