Remote Start occasionally NOT working
BroncMan
Sioux Lookout, Ontario
kr-photography.ca
2024 Ford Bronco Sport
Hey All,
please excuse posting this again but I could not find an answer in other posts, addressing the same/similar issues.
I couldn't underline "occasionally" in the title, but that's what it is ... usually starts fine, but occasionally .. no reaction ...
just the short beeps and red led on the fub. (instead the usual green).
The battery is good / no warnings when playing music after engine off, etc.
It's always from the same place / no obstructions.
I checked, when it happened, for ajar door etc.
It worked one day ... and the next it didn't ... even though the car has not been moved.
Any Ideas?
Thanks
Outback Texan
MIke
San Antonio, TX
That happens to me (Badlands) very often. The only explanation I can GUESS is that the battery is monitored continually and if below a certain charge level, auto start is turned off. When not working, the "auto start" symbol appears on the dash with the line drawn through it, showing me that it is off. Perhaps if you've been just driving short trips, the battery just does not charge up to that minimum level.
BroncMan
BroncMan
kr-photography.ca
Thanks for the quick reply, Outback Texan
Interesting!
So - it has been VERY cold for the last week (-30C overnight) and I have been away, so the car has been sitting untouched. When I came back I started remotely ... it worked! ... let it run for 10 minutes ... just being concerned and to be nice :) The next day it didn't work!
I also have to mention that the "Auto Stop/Start" stopped working in the past. I took it to the dealership and they replaced the battery, which worked fine but just not to the fullest level, (just over 12V) which prevented that feature ... and also had a warning when the radio was on after engine off "... shut off to prevent battery drainage" ... to that effect.
And yes - I only drive about 10 km to work daily.
So-could there be a correlation between short drives and cold temperature?
If so, there cannot be done much, I guess. Winter is winter and it would be odd to drive longer distances just for the battery's sake ... ??? ... or move to remote, hot Texas :)
Any further comments are highly appreciated.
Thanks
Sig Oris
Western Maine
2021 BSOB
Lots of discussion on this in the Ranger5g forum. If your doing short drives it may be in you best interest to connect a trickle charger. I have our BS-OB and Ranger connected to a CTECK changer when parked for long durations at home. We are both retired.
Fordone Badlands
Ontario
22 Bronco Sport
Interesting!
Thanks
I would connect a trickle charger at least once a week and leave it overnight or untill it indicates a full battery. I use a NOCO 2 amp unit.
BroncMan
BroncMan
kr-photography.ca
Thanks, all
that sounds to be the problem.
Sorry about my ignorance but what is a trickle charger? as opposed to a regular charger?
Thanks
PS: just looked at Amazon ... need advise:
some are 1-2 amps, others are 4 or 6 amps. (all Noco)
What effect has the difference in ampere on the performance?
Fordone Badlands
Ontario
22 Bronco Sport
Thanks, all
Thanks
Length of time it takes to fully charge a battery. Faster isn't always best.
A trickle charger is also called a battery maintainer. It's meant to be connected to your battery and left on indefinitely. If you own a toy (motorcycle/boat/4-wheeler/etc.) that you can't use during the winter months you can connect a trickle charger to the battery when you put it away for the winter to prevent battery drain.
