- Joined
- Oct 14, 2022
- Threads
- 10
- Messages
- 734
- Reaction score
- 1,634
- Location
- Greatest country on earth!
- Vehicle(s)
- This one
- Banned
- #16
Anyone can overthink this to death. Which is what happens every time the topic is brought up. lol.
Thank you once again Mark for your research and posts to explain the reasonings for this recall.This is true IF you have a fuel leak. That's not what this recall is for. A fuel leak requires immediate attention. Ford (under NHTSA oversight) has not issued a "stop drive" recommendation for this recall, which suggests it believes the risk of injector leaks to be small. The recall was prompted by field reports of 54 under-hood fires. Here's what Ford's investigation turned up (so far):
Do you think that's enough evidence to warrant fleet-wide replacement of fuel injectors? The investigation is ongoing, and it's entirely possible that Ford will discover a flaw with the fuel injectors currently in use requiring replacement. That's not currently the case.
And you still haven't. That's not what this recall is about.
Every car you've ever owned has at least one fuel drain tube. The fuel filler port includes a drain tube to port fuel spills to the ground in the event you overfill the tank. Spend some time on Google searching for "emergency fuel drain tube" and you'll find many examples.
Which is its only purpose.
I'm rapidly approaching my cutoff. Kent is right; it may be time to just stop responding. There're already more than enough words on the forum devoted to this topic.Thank you once again Mark for your research and posts to explain the reasonings for this recall.
Something in my mind tells me this will not be your last explanation on this topic.
What topic?I'm rapidly approaching my cutoff. Kent is right; it may be time to just stop responding. There're already more than enough words on the forum devoted to this topic.
Just to be clear, I know better than to question engineers. As I said, "It looks like the recall repair will work to safely divert fuel in the event of a leak."We are starting to once again question the engineers and testing that was performed to solve this issue. Since it passed the tests and was released as a TSB for repair, I'm fine with it.
I'd say we stop beating the dead horse.
Looks like I inadvertently kicked a hornets nest. It was/is honestly not my intention to get anyone riled up.This is true IF you have a fuel leak. That's not what this recall is for. A fuel leak requires immediate attention. Ford (under NHTSA oversight) has not issued a "stop drive" recommendation for this recall, which suggests it believes the risk of injector leaks to be small. The recall was prompted by field reports of 54 under-hood fires. Here's what Ford's investigation turned up (so far):
I'm betting because other vehicles have a better drainage system to divert fuel from a heated source.Looks like I inadvertently kicked a hornets nest. It was/is honestly not my intention to get anyone riled up.
From your Ford report:
"A complete accounting of all fifty-four (54) 1.5L under hood fire reports known to Ford includes: four (4) of them have had one confirmed cracked fuel injector determined from the fuel injector supplier tear-down analysis. Ford Engineering assessed the fifty (50) remaining reports, determining: approximately thirteen (13) others were likely caused by a leaking fuel injector."
So the recall is due, in part, to the fuel injectors.
That said, 17 is a very small number when compared to the total number of vehicles. It begs the question though, why don't we hear of similar issues, and recalls, with other vehicles?
Yes, the fuel filler port on essentially all vehicles includes a drain tube to port fuel spills to the ground in the event you overfill the tank. Absolutely true, however, other than the fact that it carries excess fuel to the ground, that's completely unrelated to this issue. I'm not aware of another vehicle that has a drain hose from the engine to the ground so that in the event of a fuel leak it will be safely diverted. Maybe most/all vehicles *should* have one?
Keep in mind, we like our BS BL. I'm not hating on the BS. We're just talking about a recall. They are very common -- my 2002 WRX had about 6 recalls -- a couple were very serious. One was similar to this (fuel leaking onto the engine and exhaust manifold). I still have the WRX. Since the recalls were completed it's been a great car.
So no offense intended. I'm only asking questions because this problem, and the solution, seem unusual.
Not riled up, just getting tired of reposting the same information over and over.Looks like I inadvertently kicked a hornets nest. It was/is honestly not my intention to get anyone riled up.
It's this kind of comment that leads to all the confusion on this topic. The recall is related to fuel injectors the same way brake recall was related to brake pads. The brake recall was about meeting a mandated (and logical) design requirement: to ensure the vehicle could stop within a certain distance in the event of a brake boost failure. Ford's fix for the issue was to install higher-friction brake pads. That didn't mean there was anything wrong with the pads initially installed, they just weren't capable of meeting the required standard in a very specific circumstance.So the recall is due, in part, to the fuel injectors.
...with this comment?It begs the question though, why don't we hear of similar issues, and recalls, with other vehicles?
Search on Google for fuel leak recall and see how many hits you get. For some of these, the manufacturers and the NHTSA determined component replacement was necessary. So far, they have not determined injector replacement is necessary for this recall.One [recall for Subaru] was similar to this (fuel leaking onto the engine and exhaust manifold).
None taken. It IS unusual; leak management is engine design 101 stuff, so it's rare to see a manufacturer make a misstep in this area. The only reason I keep responding to these posts with such vehemence is because I am trying to prevent another urban legend. Every post made about "faulty fuel injectors" is another hit on a Google search. I'm hoping anyone that follows a link to this site sees my responses as well. The bottom line is there is no evidence (yet) that the fuel injectors used for the 1.5L EcoBoost engine are faulty, substandard, poorly made, or in any way more prone to failure or cracking than those used by other manufacturers.So no offense intended. I'm only asking questions because this problem, and the solution, seem unusual.
They may, but I just searched for, "drainage system to divert fuel from hot engine components" (among other search terms) and all of the top results were for airplanes.I'm betting because other vehicles have a better drainage system to divert fuel from a heated source.
It would be nice if companies could use plain simple language to explain these issues but lawyers get involved and that means these messages pass through multiple people/committees to sculpt the language to protect themselves.Mark,
It's true that the early WRX models had the fuel leak I mentioned (typically it was in single-digit temps and below) but that's where the similarity ends. One difference is how Subaru responded. Initially, they told owners to pound sand, but when the NHTSA got involved they began to act like 'responsible corporate citizens'. Another difference between that WRX recall and this one from Ford is that with the there were known incorrect parts that Subaru replaced -- as opposed to installing a fuel drainage system.
It was a different situation. The fuel leak in the WRX was due to an engineering defect -- failure to account for differences in expansion/contraction rates between fuel line and fuel house. Almost all of the early WRX models had the problem. So it made more sense for Subaru to just replace the line and/or hose causing the problem. Unlike this situation with the 1.5L recall, a fuel drainage system would not have been appropriate.
BTW -- that was an EXPENSIVE recall for Subaru because the boxer engine has the intake manifold on top, spanning the block, from one head to the other, with the fuel lines attached underneath -- so a bunch of stuff had to come off. IIRC, it was about a 6+ hour job.
Back to the 1.5L Eco-boost recall, I found this from the Ford Medi Center:
https://media.ford.com/content/fordmedia/fna/us/en/news/2022/11/24/ford-alerts-customers-that-certain-2020-2023-my-bronco-sport-and.html
The projected injector failure rate is low -- .22% according to Ford -- but when their headline, in large bold font, is:
"FORD ALERTS CUSTOMERS THAT CERTAIN 2020-2023 MY BRONCO SPORT AND ESCAPES MAY HAVE A CRACKED FUEL INJECTOR"
And Ford goes on to say:
DEARBORN, Mich., November 24, 2022 – Ford Motor Company will urge owners of 2020-2023 MY Bronco Sport and Escapes with 3-cylinder, 1.5L engines to visit their dealership to inspect for a potential cracked fuel injector.
When the engine is operating, a cracked fuel injector could cause fuel and/or fuel vapor to accumulate near hot surfaces, resulting in a potential under hood fire."
it's easy to see how an urban legend might get started. After all, that's from Ford, not some click-bait site.
If we had the 1.5L, I wouldn't worry excessively about this issue -- just have the recall work done and go on down the road.
At the end of the day, we're just talking differences in semantics:
* Ford should have said essentially what you did -- that the vast majority of fuel injectors are fine, but IF one fails, they want to be sure any leaked fuel is directed away safely.
* Most recall work will not involve replacing cracked injectors, only installing the drainage system.
It's really a shame Ford worded it the way they did. Here's another:
https://www.ford.com/support/how-tos/recall/recalls-and-faqs/bronco-sport-escape-fuel-injector/
And a typical media report:
https://www.nbcdfw.com/news/local/recall-alert/ford-recalls-over-634000-suvs-due-to-fuel-leaks-and-engine-fire-risk/3133541/
Very true.It would be nice if companies could use plain simple language to explain these issues but lawyers get involved and that means these messages pass through multiple people/committees to sculpt the language to protect themselves.
BTW, not all direct injection engines have the injectors on top of the engine like the Ford design. I'm not saying Ford's design is bad, just that other variations exist on GDI engines.
