noises .... noises everywhere
thekingprawn
Dustin
Kingston, Wa
Loud music fixes all. I don't think I have any noises though.
22 BL with about 2500 miles. Backseat passenger side somewhere it has a creak that comes and goes. When it's there it's annoying though. Hopefully it'll work itself out or I guess I'll see if they can check when I take it in for an oil change.
Hi there, Patrick! I can look into your Bronco's noise concern on my end. To get started, could you please send a private message over with the name/location of your local Ford dealer and your Bronco's VIN?
toddedmond
Todd
Weirton, WV
2020 Camry XSE
Mine is now up to 23000 miles(trouble free). I have had three different noises.
*Tapping type noise from both front doors. Turned out that it was the mirrors. I was able to duplicate it by tapping on the mirror housings. I fixed it by taking apart the mirrors, which wasn't very hard to do, and installing some felt tape around the perimeter of the mirrors where they attach.
*The infamous "clicking and clacking" from what sounds like inside the drivers dash. I did my own troubleshooting by disconnecting the shift release cable, which quieted it. My dealer replaced the cable with a revised part and noise is gone.
*Had a loud rattle/grinding noise that came from rear of vehicle. I feared the worst that it was the rear diff. I noticed by watching the "intelligent 4WD" screen that it only made the noise when rear was engaged. Dealership said they couldn't duplicate the problem. I found that the heat shield that is above the rear drive shaft somehow moved and was rubbing the drive shaft. I noticed it by seeing a shiny stripe on the rusty drive shaft where it was rubbing. I was able to bend and tighten the shield, and have never had it happen again.
Rygar
Riley
Saskatchewan, Canada
Infiniti FX35
I get a somewhat consistent creaking or clicking sound coming from the dash that drives me nuts some days. At about 4000km I started to get some creaks and squeaks coming from the sunroof as well, but they aren't as annoying.
The Bronco was rock solid and silent from 0-3500km which was really promising. Hammering on the soft material panel on the dash with my fists in rage does alleviate the noise for a short time.
Palom0
Argentina
Bronco Sport 2021 Wildtrak, Carbonized Gray
'21 BS Wildtrack here. I have been having sunroof creaks for months already.
I brought the BS to the dealer to check it out but they couldn't make it go away.
It is a small creak that can only be heard if the sunroof liner is open. If closed, I can't hear it . Still quite annoying, but I can't find any way to completely eliminate it.
If you are able to kill it, please let me know.
kennyroo
Kenneth
San Diego
i get this weird creek or sound on my driver side window, it’s like the gap between the window and side panel that tap and make this sound, i almost want to put something there to silence it lol if i stick my finger in between that gap it goes away. other noises have come and gone like the dashboard where the radio is situated , could be breaking in noises because it’s new but the most persistent is my window noise, hasn’t gone away
Vespesian
ON, Canada
Make sure your window is alllll the way up...I had the same sound until I realized the window was about 1/8 inch shy of termination, which, btw, isn't apparent by eye.
Hey there! I can look into your Bronco’s noise concerns on my end if you’d like. Will you send us a private message with your VIN and dealership info?
kennyroo
Kenneth
San Diego
it’s definitely closed all the way
