My 2021 Bronco Sport Transmission Issue
RiotfunK
Mass
22 Bronco Badlands
I think it’s the way the 3cyl is tuned under 2300 rpm. Feels like someone letting out the clutch and then trying to not stall by giving it gas. Is loud chatter and delay in power. Putting in sport mode gets rid of this feeling. Going off of escape 3 banger I have as a loaner. It feels terrible to drive
JRCLT59
James
Charlotte,NC
2021Ford
having the same issue around the same mph's as well. it just shutters and shakes and trembles and then I hit the gas and it goes away which leads me to believe its some sort of turbo issue maybe? I'll try the sport mode, I just hit the 1,500m mark. I have a 22 OBX.
This issue seems to have my dealership scratching their heads. Can’t figure it out
AndyMac204
Andy
i have the shudder, for 40,XXX kilometers now. Nothing will blow up but it is there. If i remember correctly there was a thread somewhere stating the condition is from the torque convertor?
V8 Yankee
Harold
Miami
21 Bronco Sport
I was corrected and rightfully so on my use of the term Turbo Flutter. I did a deep dive into the term, cause and effect and it definitely is different from what I was trying to convey. In my case the flutter noise would be more accurately described as Turbo Rattle, or more specifically Waste Gate Rattle. Sort of sounds like a air compressor at low rpms. Ford has a Technical Service Bulliton on the issue on EcoBoost 3.5s and 2.0s. I'm not positive yet that is what I'm actually hearing but it gives me something to follow and figure out. Combined with delayed shifting into a lower gear I get the transmission shudder (lugging) feedback plus the audible feedback as well. It's easy to correct and is brought about by my very light foot on the peddle. I'm always doing the hyper mileing thing even in the city when traffic is light. Sorry if I misconstrued Turbo flutter with Turbo rattle.
FuryMachine84
U.S.
2023 Ford Bronco Sport
Hello, just going to throw this out there. Is it possible your perceived transmission shutter is actually turbo flutter. When there is a "under-boost" condition it can feel and sound like transmission shutter at low speeds, aka parking lots, etc. This is brought about by the trans not shifting down, can also feel like lugging, using a manual transmission term. As mentioned shifting into Sport Mode will eliminate the flutter by going into a lower gear and boosting intake pressure at the same time. It's a slight inconvenience to do this but try it. If there is transmission reprogramming fix in Normal Mode I haven't heard of it. This might be a question to ask Ford Service.
I get what you're saying but no. Putting it into sport does not eliminate it. And if it is turbo flutter or trans putting it into sport mode, youll be adding more boost & increased line pressure in the trans. Which is liable to make your problems get much worse vey quickly.
V8 Yankee
Harold
Miami
21 Bronco Sport
Since I posted that I researched the rattle in depth and became more versed in the subject. I narrowed the sound to more of a rattle than flutter. I started running 93 octane and used the low gear button on the gear selector when my speed was under 15mph. The trans was staying in 3rd gear so I was lugging the engine and getting some pre-ignition. Once the engine dropped into 2nd the rattle, flutter, lugging disappeared. I attribute my intial response to lack of research and a cheap set of ears.
