The tires look good and I’m glad they worked well for you.You were 100% correct in what you said about my tire deal , my Goodyear workhorse A. Fit as you said they would , at 30 inch with no spacer and no lift and keeping with the 235 and 70 side wall with a stock rim , they fit and ride perfect. With a 1/2 inch space front and back of the front wheel , definitely fills the wheel well . Not going to go with any rock crawling. The size of the wheel well is constant. Thanks for your expertise. Take a look see .@Meanderthal
Oh by the way what do you think of the wrangler on a bronco deal ?
You say that there is 1/2” clearance front/back. What I would ask is that you turn the wheel fully one way or the other and check clearance front/back on each side. Then report back with the clearance values you find.
