Help with horn beeping on exit when running
Curious? Coming out of Left field…Using 2Fobs, leaving 1 taking 1 ? ? ?
Also If I left one could I still lock / unlock?
I’m currently Overseas so I can’t just run out & check.
Yes you can leave a fob in the car and still use the other to lock and unlock. Alternatively you can also use the touchpad if equipped or the FordPass app
As @Jmuns said, you can leave a fob in the vehicle and lock with another, but be advised that if someone is able to get inside the vehicle--say, by breaking a window--they can disable the alarm and drive away with your car by simply pressing the START button on the dash.
kshaw
Kent
Gaithersburg, MD
@kshaw Can you please share a PDF of your FORScan spreadsheet?
Btw Post #247 was updated today with a few more FORScan items but without the details of how to accomplish (added item 2b and items 11-14 on that Post #247)
https://www.broncosportforum.com/forum/threads/bronco-forscan-thread.844/page-17
I have mapped the ForScan options but have not documented possible changes that can be made. Also, there are two versions of what can be done: one is labeled (AS BUILT) and those involve changing certain bits in 12 byte configuration which is higher risk. The other version is a parameter list of items which can be changed. I plan to focus on the parameter list first before tackling the AS BUILT.
