How are you liking the H&R srpings?I had them installed as I was not happy with the 2” Belltech spacer lift.
ride is so much better and no clunking noises.
What skidplate is that? I found it. Rally Innovations.Love the springs. No clunk anymor.
I switched out my flares over the weekend.
Nice wheels.Love the springs. No clunk anymor.
How much of a difference in mpg do the lift and tires make?Love the springs. No clunk anymor.
Looking and standing tall , nice look .Love the springs. No clunk anymor.
What if I may ask is your overall height to the top of your roof rails that came with your ride , the factory rails. ThanksHow much of a difference in mpg do the lift and tires make?
what rack is up top?Love the springs. No clunk anymor.
I’m confused.
seems spacer lifts have many issues, now we are seeing spring lifts and a far better ride quality and less or no obnoxious noises or problems, correct ?
Spring sag is important, we need an inch or so of negative travel, like when you get on a shop lift and the wheels extend to max travel.
The factory shocks were part of the suspension tune as was the spring rate that allows better use of the full travel range.
Stay with me,,,,,,,,
Shocks need to have travel in both directions for proper articulation correct ?
Taller springs go on, are the shocks now extended so there is little or less rebound travel ?
Will they be hitting their max extension length more often ?
Will this break them ?
Did that make any sense ?
