DRL’s not shutting off
I had the same problem and used to apply the same solution explained here about locking-unlocking-locking etc. I also don't believe battery saving is working well in this case. But recently I noticed that if I lock the doors after the lights delay (set to 10s in my case), the "glitch" doesn't happen. Now I only close the door after 10 seconds, enough time to organize my objects before getting out of the car. By doing it this way, the problem has not happened again in the last 15 days. Obviously we shouldn't have to change habits because of a car, especially when it's a car function that doesn't do what it's supposed to, but this procedure I described has worked very well for me and I think it could help someone else. Just give it a try.
Have you looked into having the dealership check the headlamp switch? It’s the most common cause after all the owner caused scenarios that keep the lights on longer than programmed per the Settings timeout (the one you set).
Headlamp switch was an issue for some earlier model years.
glbr
Geraldo
BRazil
I hadn't considered this possibility, thanks for the tip. Since it's working fine the way I described, I think I'll just take care of it the next time I send the car to the dealership for annual maintenance. Hoping that another problem doesn't appear sooner. Best regards!
Quashish
Tomas
Sacramento
2024 Bronco Sport Badlands
ours does this randomly too. sometimes headlights as well as running lights stay on after locking mostly just running lights by themselves though. these cars have so many issues and quirks its sad. ford should recall them all.
best cars ive ever had were 4th gen honda accords. seriously considering getting back into those and picking up a wagon
