We traveled up to Ticonderoga from Schenectady tonight and I found something interesting. I thought at first I was mistakenly tapping the Cruise Set [+] and [-] keys . I would go Around a turn and suddenly the set cruise speed would change and be set to higher speed. Sometimes it was 20+ miles faster than what was set .
Then I got to a straight-away and I noticed it was happening the the posted speed limit changes, and the Speed Sign Detection would update the posted speed in the cluster. IF i set the speed to 40 MPH and the limit was 45, then changed to 55, the set speed would jump to 62MPH.
It did not have any effect when the same speed sign would show as the last one, only when a change in posted speed limit would change.
I done remember if this happened before today. I was in ECO mode, and switched to standard mode. No change
I power cycled the engine, no change.
The amount the set speed changed was inconsistent, however it happens at every posted speed change while I was using adaptive cruise.
This seems dangerous. I wonder if there is a firmware update or recall on this.
