Bronco struggles to turn over - getting Charging System Service Now message + multiple alerts upon ignition
So…this is exactly what the dealership initially told me and sent videos of. However while “making sure”, it turned into “the water pump is leaking onto the alternator, which damaged the alternator.” So now it is a $2500 repair out of nowhere…
This doesn't make sense to me. If I recall, the water pump is installed below the alternator. I don't have a 1.5L engine, so I can't go check. Can anyone confirm?
JRav007
JRav007
J.
Atlantic City, NJ
Mark…thank you!
I’ve been digging trying to find out if this is even possible, but can’t confirm the positioning of the water pump in relation to the alternator on the 2021 Bronco either.
Anybody know if the positioning of the water pump would allow a leak (also i have NO areas in my driveway showing any leakage) to soak the alternator like is being suggested?
cprcubed
Patrick
Parker, TX
Alternator is above and slightly forward of the water pump. I would think it would have to be a good-sized leak to cause alternator failure. My pump has a small leak and I can see the dried coolant residue on my underhood insulation from spray off the rotating pulley/belt. Cheers!
The alternator on the 1.5L engine is located above and to the side of the water pump.
It is impossible for the water pump to leak directly onto the alternator.
JRav007
JRav007
J.
Atlantic City, NJ
Thanks everybody for your replies.
I dig further at the dealership and was told the water pump leak was spraying the alternator, and that is what caused the issue. They say that the alternator is not testing consistently and goes in and out.
I’m not that mechanically knowledgeable… nor have a lot of time/resources to run this all over getting other opinions, so I went for the repair.
It was supposed to be done today, but now they are telling me that the alternator they received from Ford as a replacement is ALSO defective and they need to wait for another.
Not going well…haha.
If I were you I would demand they give you the "failed" alternator. I'm overwhelmingly skeptical that a water pump leaking so badly it is "spraying" an alternator installed above it, yet doesn't leave any coolant on the ground. Doesn't pass the smell test...
Not being argumentative but there are owner reports of 1.5L water pumps that were defective (“leaking”) however the owners stated no coolant was ever seen on the ground — instead they noticed the under hood insulation was holding the coolant spray. So it does seem plausible the leak could spray towards the alternator. Perhaps the 1.5L owners should fashion up some sort of shield to prevent a water pump spray from reaching the alternator… would be a good aftermarket item something JC Whitney would want to carry — over 400,000 potential customers ?
Not being argumentative but...
Sure you are! There's nothing wrong with that. This forum is for sharing information; if someone has it wrong we should correct them, and that includes me!
Hmmm. I missed those posts. If that's the case then it seems to me the smell of coolant would be overwhelming. @JRav007, have you been smelling coolant? Can you open the hood of your car and take a sniff? If your water pump is spraying coolant everywhere you should be able to smell it. It's kind of a sickly-sweet smell.
grand_larseny
Rebecca
Did you end up with a resolution? My 2021 Outer Banks was just in due to overheating. They thought it would be the water pump but turned out to be something else. A week later my “Charging System Service Now” light came on. Dealership ran for codes and nothing popped up so I was told to continue to drive it. Coming off the freeway later in the day a ton of warnings started popping up and my car died. Towed back to the dealership. After almost a week and a new battery the problem was supposedly fixed. I went back to pick it up tonight and the light came right back on. I’m wondering if it’s the alternator or if they didn’t perform a reset after the new battery install.
Chiefthepup
Colt
Washington
When you say it turned out to be “something else” in relation to your over heating, do you mean they installed something else as a fix? I ask cause if they went pulling things out it’s a very high probability a ground got knocked loose or a ground wasn’t tightened completely after removing. Keep us updated!
