Here's that thread: https://www.broncosportforum.com/forum/threads/aftermarket-steel-wheels-for-bronco-sport.1565/Someone else mounted on escape rims. Perfect fit.
Also, bear in mind that tire manufacturers want you to use as many sets of tires as they can get you to purchase, AND the warranty is based on odometer readings, so they want you to have the winter tires setting in the garage for at least 1/2 of the odometer based waranty!Keep in mind that snow tires are not recommended in warm weather due to their soft compound, according to Michelin:
They may not honor the warranty if the tires are used outside of their recommended temperature range. This is due to the soft rubber compound overheating in warm weather conditions.Also, bear in mind that tire manufacturers want you to use as many sets of tires as they can get you to purchase, AND the warranty is based on odometer readings, so they want you to have the winter tires setting in the garage for at least 1/2 of the odometer based waranty!
