Anybody else use ceramic coatings?
retiredguy
I used adams polishes graphene ceramic coating. Looks great! Before and after
Ford Bronco Sport Anybody else use ceramic coatings? 49E2DCA4-D11A-484E-878C-A9AFCE6FF361
Ford Bronco Sport Anybody else use ceramic coatings? E1BAEDA9-5460-439E-9D37-310B0A5F90B5
Looks great. Did you have to do paint correction prior to the coating?
Fink
Fink
Ryan
Ohio
I did. I bought it in February right before a snow storm and drove it around for a month prior to doing it. I notice in that short time the section under the tail lights were getting scuffed up really bad from road debris. So corrected there and minor scratches that I seen from at the dealer. It wasn’t bad but noticeable. I also put the splash guards on to help protect the paint from road debris.
In all honesty I actually haven’t drove it since.
Thanks guys! I try to keep it nice. I’m very particular about how my vehicles look.
Well I'd say you took care of it. I have two coats on mine now and I sincerely dont see as many bug splats and even dust seems to be minimal. The surface is incredibly smooth. I didn't need any paint correction, the surface was spotless and I coated early enough. Winter here will be the true test.
Fink
Fink
Ryan
Ohio
For sure. I might go get it under coated or do it myself. Maybe a spray on Bedliner would be better?
Fink
Fink
Ryan
Ohio
Yeah not a bad point. May have to look into that myself.
Por 15 makes really good products. I used it on my spitfire both for the frame and gas tank. So I might use that instead. But if I off-road it might not hold up to that. Spitfire isn’t going off-road for sure.
Fink
Fink
Ryan
Ohio
Did you put it on the windows, trim, and lights as well?
Yes I did, also did the rims. Adam’s can go on everything. They also encourage that when you put it on you windows you do it to the blades as well. They said it squeaks and jumps if you don’t.
I tried that product the last coat and I am happy with that as well.
Ford Bronco Sport Anybody else use ceramic coatings? AAE5CE93-F21E-458F-ACF6-121E0F320E3C
Ford Bronco Sport Anybody else use ceramic coatings? 4D2176E5-727B-47A6-8F39-981E525C0664
I use Torque ceramic finish, 3 coats good for a year .
Ford Bronco Sport Anybody else use ceramic coatings? 4440CF20-5C58-4A44-A899-DC79CD3B37FC
Ford Bronco Sport Anybody else use ceramic coatings? 8F3BECB4-C505-4CB1-B571-C8555951430E
dejones64
Dan
MN
Lancer, BS BB
I'm gonna try Fluid Film for undercoating. Not sure about that spray on bedliner type stuff, as I've heard that if it develops a tear or hole, water/moisture/salt can get into it and then it's trapped inside.
