Another Coolant Leak (But not the Pump)
JC3
College Park Md
2022 BS
2022, Big Bend - 18K Miles.
I noticed a faint smell of coolant and assumed the pump was going. I saw evidence of a leak at the pump and took it to the dealership. After pressure testing the system, I was told it is leaking from the thermostat cooler hoses (circled in diagram) and it would be $1,600 to repair as the extended warranty doesn't cover hoses! Apparently, the alternator has to be removed which drives the hours much higher. Have any members encountered this particular leak and does this sound reasonable?
Ford Bronco Sport Another Coolant Leak (But not the Pump) Bronco Sport Cooling
Ford Bronco Sport Another Coolant Leak (But not the Pump) 1769135073197-zl
logant
Out of curiosity for future reference - where did you get your colored parts diagrams?
Thanks
BroncoSportInDMV
Virginia
2025 Bronco Sport Big Bend Eruption Green
What extended warranty do you have?
logant
Ford ESP PremiumCARE - I reviewed the terms of the contract and it looks like coolant hoses are considered a wear item and aren't covered...
Interesting - I have 1 2003 Explorer Sport (2 door) and have never replaced any coolant, hose, or pump in the entire system. You'd think that a 'wear' item would fail inside of 23 years
Ernest T
Dennis
Central Texas
I had a 1997 F150 with the 4.6L V8 for 20 years and 200,000 miles without ever relacing a hose. I've had to replace the water pump and two hoses on the replacement 2017 F150 with 5.0L V8. Reliability has definitely taken a step backwards.
JC3
College Park Md
2022 BS
A quick closeout to this thread and another confirmation about dealer practices! The Ford book estimate of 8 hours was a bit off. I took the vehicle to a reputable independent shop after purchasing the parts and coolant myself. Total cost of the hose, clamps and coolant was $160. Labor cost at the shop was $168. Unbelievable, they replaced the hose in 90 minutes, hosed off any residue and topped of the coolant. I checked the work and everything looks right. I am grateful for an honest job done...
