Alternator OAD Pulley Replacement Part #
SHAKEmeBUNS
George
2022 Bronco Sport Outer Banks
For anyone trying to avoid buying an entire alternator assembly from the dealer, here ya go....
The the pulley is made by Litens part #920123 920123A or 920123K for roughly $50. I found one on Amazon. Another forum member also found it on RockAuto.com.
I went with a new serpentine belt from NAPA #060452 for $35
I recommend renting a decoupler tool from AutoZone for fast removal.
No need to remove the alternator or pay the dealer $500.
There's plenty of great YouTube videos showing how to remove it, but here's a few pics from today's project. Takes just over an hour.
Zip tie the new belt to the crank pulley, rotate it and it pops right in. Good luck out there....
Ford Bronco Sport Alternator OAD Pulley Replacement Part # 20260406_125924
Ford Bronco Sport Alternator OAD Pulley Replacement Part # 20260405_144419
Ford Bronco Sport Alternator OAD Pulley Replacement Part # 20260405_151029
Ford Bronco Sport Alternator OAD Pulley Replacement Part # 20260405_150716
Ford Bronco Sport Alternator OAD Pulley Replacement Part # 20260406_100847
Ford Bronco Sport Alternator OAD Pulley Replacement Part # 20260406_131236
Ford Bronco Sport Alternator OAD Pulley Replacement Part # 20260405_144543
Ford Bronco Sport Alternator OAD Pulley Replacement Part # 20260405_144159(1)
Ford Bronco Sport Alternator OAD Pulley Replacement Part # 20260405_144259
Ford Bronco Sport Alternator OAD Pulley Replacement Part # 20260405_144252
Ford Bronco Sport Alternator OAD Pulley Replacement Part # 20260406_132240
Nice work. I recall replacing a similar coupling on an old washing machine. I didn’t realize the Sport had an alternator with an OAD pulley. Another thing to break that doesn’t need to be!
SHAKEmeBUNS
SHAKEmeBUNS
George
It's supposed to preserve the belt and alternator by allowing it to freewheel, but I was driving in the desert in Baja and was forced to drive it back to the states broken and squeeling for another 16 hours! It damaged the alternator and I had to cut the belt to replace it 🤦🏽
Ford Bronco Sport Alternator OAD Pulley Replacement Part # 20260326_093654
So did you end up replacing the alternator as well? Could you buy that without the pulley?
SHAKEmeBUNS
SHAKEmeBUNS
George
No I didnt. The bearings were still spinning freely. Looks like it was just grinding the front face of the alternator. Going to ride it out and get as much life out of it as I can! Ford dealer only sells the whole assembly.
Ford Bronco Sport Alternator OAD Pulley Replacement Part # fbe091186836b92740e9cd847b87a186
