Aftermarket Wheels and Tires - 245 65 R17 vs 255 65 R17
ral19
Ryan
Flagstaff, AZ
Hey everyone, I’m usually poking around on these forums regarding aftermarket wheels and tires but I haven’t found 100% of what Iv been looking for.
I have a 2021 OBX and want to do one of the 1.5” lifts (either HRG, readylift, or RC) and go down to 17” icon journey wheels. I know everyone does the 245 65 R17 tire size for aftermarket, but Iv been curious on if anyone has done a 255 65 R17 (or similar size) to get a little more width and poke from the tire? It’s a half inch wider than the 245 but I wasn’t sure if anyone has done that setup with the lift as well as if it rubs or not? I should note too the offset on the wheels I’m looking at is very similar to stock at 38mm.
Any help or guesses is appreciated, thank you very much.
There's a few people here running 255/70/17's with 1.5 inch lifts and claim no rubbing.
Lots of threads/posts here about tires and lifts, just do a search.
ral19
ral19
Ryan
Flagstaff, AZ
Yeah, I have seen one on here at least that is running 255 70 17s but it's with a slightly taller lift and badlands which is already taller anyway. That one didn't rub with the specs that he had on wheels and tires but it's a lot more lift than what I was planning on. Thanks for the advice though I'm going to keep poking around on that size and if anyone has done it on an OBX.
Discount Tire
Diamond Sponsor
Arizona, USA
discountti.re
All Things FORD
@ral19 just a thought, the 245 being more popular has readily available options in Falken A/T Trails, Nitto Nomad and Ridge Grapplers Etc, for example. I think as the 255 becomes more popular that might be the way to go. For now, I would recommend the more common size for convenience. That's a great looking wheel by the way. :thumbsup:
ral19
ral19
Ryan
Flagstaff, AZ
Very true, I have been pretty set on ridge grapplers but they don't have them in 255 65 17, I have seen the Falken Wildpeak AT3 in 255 65 17 which is one I looked at as well. I just wanted to get a little more width without having to trim/rub. Thanks for the input.
