3rd window vinyl decal
C.D.
Collin County, Texas
I’m new to putting on vinyl decals on my 3rd rear and I failed horribly. I was using a credit card to smooth it out as I slowly applied. The first one had several bubbles that I planned on picking with a needle. The other side was the most difficult and began to bunch up. I’m thinking the heat had something to do with it. Any suggestions would be greatly appreciated. Thanks in advance.
ChefDank
Nick
New York
Take a spray bottle with 1 drop of dawn and mix. After cleaning service with alcohol and dry; spray area with soapy water then apply vinyl and squeegee from the middle out to get all bubbles and wrinkles out. Then allow to dry; the soapy water gives you some play with the graphics. Hope this helps
CherokeeLawman
C.D.
Thank you for the speedy response.
ZeroCool
Oh
I watched youtube vids to before installing as i had never done wet decals.
NJBronco
Min
NJ
spray what you think is too much, then spray some more
Exactly. Spray more than what you think. First time for me and wet method even though the instruction said to apply dry. Worked like a charm and much more forgiving. Good luck
