265 60 R18 will fit but....
Dangerduane
Dangerduane
Duane
Albera Canada
See the difference from stock rim tire to the ones i installed
Ford Bronco Sport 265 60 R18 will fit but.... Screenshot_20220505-152902_Tire size calculator
You have the 1.5” lift and still needed to trim?
A lift does not change the clearance when the suspension is highly articulated, it only changes at what point in the articulation the interference occurs. If you are building a “mall crawler” then you can lift it and put huge tires on it. You will then have to drive cautiously over bumps to avoid tire rub, much like a lowered car driver does. A lift only changes the situation slightly, it is not a solution.
