2025 MY Bronco Sport Goodyear Tires
I was told by the DT phone rep and store manager that it's a Ford spec tire. In any case, I'm happy with them.
The key is OEM part# 59000690 is Falken’s part # for the Ford spec tire for ‘21 to ‘24 BS. You’ll find it on Falken’s website in their list of tires. That part# 59000690 is what Discount Tire and others sell under their own part numbers. No worries.
jj1
MY 2025 Bronco Sports and Mavericks can be ordered with the Goodyear Territory RT All Terrain 235 65 R17 tires available in specific packages.
Here’s the information for that tire including its Part # (aka Product Code) and tire weight:
Goodyear Territory RT All Terrain 235 65 R17 104T
(M+S Mud & Snow)
(3PMSF: Three-Peak Mountain Snowflake symbol, meets Severe Snow Service performance requirements)
Part # (aka Product Code):
710004933
Note (edited 8-15-2025): see this post for actual measurements
https://www.broncosportforum.com/forum/threads/2025-sasquatch-goodyear-tires-do-fit-in-spare-tire-area-with-mods.17101/
Tire weight: 29.56 lbs
Tire Diameter: 29.06" (29.5” measured)
Tire Width: 9 3/8" (measured)
Tread Depth: 12/32"
Tire mileage warranty (miles): TBD
Standard Load
Made in Canada
Radial Tubeless
104T:
• Load Index: 1,984 lbs per tire (900kg)
• Speed Rating: Up to 118 mph
TREADWEAR: 580 (Uniform Tire Quality Grade (UTQG) rating: expected to last 5.8x longer than a tire with a treadwear rating of 100, which is the base or control tire)
TRACTION: B (Tires are graded for traction using a system of letters: AA (highest), A, B, and C (lowest). B: Represents moderate wet-grip performance, meaning the tire can stop on wet pavement, but not as quickly as tires with higher ratings)
TEMPERATURE: A (highest level of heat resistance and the tire's ability to dissipate heat, meaning it's designed to perform safely at speeds exceeding 115 mph)
PLIES:
TREAD:2 POLYESTER + 1 STEEL + 1 POLYAMIDE
SIDEWALL: 2 POLYESTER
Max Pressure: 51 psi (350 kPa)
001298/2012: TBD
Internal Goodyear numbers:
GSWR79994A
T398366
GP-3105ADADAD
DOT 14B81 PY1R 4324
14B: manufacturer and plant code where the tire was made (Goodyear Canada, Inc. in Napanee, Ontario, Canada)
81: Tire size and type code
PY1R: internal code used by the manufacturer
4324: week and year of manufacture (43rd week of 2024)
We took the OEM Goodyear tire off of our 25 Badlands Sasquatch immediately and put more robust tires on it.
(M+S Mud & Snow)
710004933
Tread Depth: 12/32"
Standard Load
Made in Canada
Radial Tubeless
104T:
PLIES:
001298/2012: TBD
GSWR79994A
T398366
GP-3105ADADAD
DOT 14B81 PY1R 4324
we replaced this tire after two days with Coopers
Did you sell the 4 Goodyear tires?
