1.5" lift kit
Sldavid
Sankalp
I would have them check again, does not make sense , check around tranny for disconnect.
Thank you. I’ll have it checked again.
The shop that did the lift needs to fix the problem it created. If it can’t find the problem then you have to take it to a dealership and the shop that broke your car should have to pay the repair bill.
Sldavid
Sankalp
Yes they have told me that if ford is not able to fix the problem or refuses to help because of the lift, they will take out the kit and issue a refund.
the.harold.c
Chris
TN
Note to self: Resist the strong urge to lift your new Bronco Sport. It looks great the way it is. Just needs some slightly more aggressive tires.
Ford Bronco Sport 1.5" lift kit TerraGrapplerG2
THIS! I’ve had lifts (Spacer and springs etc.) on multiple F150’s and had a myriad of (mostly minor) issues - but they were troublesome enough to steer me away from doing anything to my B.S.
Colonel Angus
Dean
New York
Amen brother.
Sldavid
Sankalp
Update for 4wd fault issue -
Finally got my Bronco Sport back from Ford service centre. The connector c1898c was broken. They repaired it. So now no more error.
