1.5" lift kit
Raybj
Ray
Connecticut
2023 Bronco Sport Badlands
2023 Bronco Sport Badlands.Installed a Eibbach 1.5" lift. It appears that the new springs may be rubbing on inner fender!!
Appears the springs may be to big in diameter?? The new spings are installed on original struts.
Ford Bronco Sport 1.5" lift kit 20230808_104138
Raybj
Raybj
Ray
Connecticut
Pics aren't very good
Eibach doesnt offer a 1.5" BS Badlands lift
Was the correct P/N kit used, the Eibach BS Badlands lift is 1.0" the other BS models are 1.7"
Who performed the install. The original orientation of the strut needs to be noted before disassembly and then reassembled with the new springs in the same orientation, if not issues arise.
Raybj
Raybj
Ray
Connecticut
It appears that the springs are to big in diameter!!
Sldavid
Sankalp
I just got a lift done on my bronco sport big bend. 4wd fault error popped up. The mechanics were not able to figure it out. Any idea why it might have happened?
Check all your sensors underneath for a disconnect.
Sldavid
Sankalp
The mechanic did check it. Said they cannot find any disconnect nor any wire was cut nothing. If I go to Ford they might create issues pointing out to the lift as the issue. I don’t know what to do.
I would have them check again, does not make sense , check around tranny for disconnect.
