2023 Ford Bronco Sport Continuous issues
  • Thread starter Deleted member 10264
  • Start date
  • Watchers 12
thomasm23
Los Angeles Metro
I've had all these same issues as well. 55k miles and had the water pump replaced 3 times. Thats not normal at all. All brakes and rotors had to be replaced at less than 10k miles. thats not normal either. countless recalls, dash lights. odd noises. theres no end to this. Worst decision I ever made buying this thing.
Please explain yourself regarding the brake issues you have had.
My brakes lasted longer than any vehicle I have ever owned. The rear pads were replaced at 117,000 miles. The front pads lasted even longer.
https://www.broncosportforum.com/forum/search/2511458/?q=Long+lasting+brakes&o=date#:~:text=Premature wear on rear brake pads (3mm at 20,000km),-I
Stircrazy
BC, Canada
Just wanted to share my experience and see if anyone else is dealing with the mounting number of issues that I am dealing with my 2023 Ford Bronco Sport Outer Banks.
From the rear callipers making obnoxious noises when cooler air to two failed water pumps, these issues never seem to end.
I am now going in for my 5th! Time regarding ABS fault /A Christmas tree of lights due to what I thought was a failed speed sensor.
Although the sensor was replaced I am still having the same issues. Now my local dealership is telling me that the wires for the sensor are being corroded at different places, yet the only way to know if it fails is once all the lights start to come.
I have had the vehicle fixed again today due to another part of the wire that corroded.
I have also been told that due to wear and tear of this 2 and half year vehicle 83000km there is nothing that can be done as it’s normal for any car.
If the issue does happen again, I am told that the entire wire harness would have to be replaced…..
I was always under the impression that these harnesses are protected from the elements/ harsh conditions for Atleast 5-10 years maybe longer before they begin to deteriorate.
Overall, just wondering if anyone else is facing these same issues.
did you get warenty? I have 100000km on my 2023 outter banks in the interior of BC where we use salt on the highway every time it snows, I also drive that highway 2 hours round trip a day for work. I haven't had any issues like this. in fact the only issue I have had since I bought this car was the cat cracking.
I would keep any recipts you get if you are paying out of your pocket just incase they find an issue that is wide spread and decide to recall it.
