2023 Ford Bronco Sport Continuous issues
  • Thread starter Deleted member 10264
  • Start date
  • Watchers 8
Just wanted to share my experience and see if anyone else is dealing with the mounting number of issues that I am dealing with my 2023 Ford Bronco Sport Outer Banks.
From the rear callipers making obnoxious noises when cooler air to two failed water pumps, these issues never seem to end.
I am now going in for my 5th! Time regarding ABS fault /A Christmas tree of lights due to what I thought was a failed speed sensor.
Although the sensor was replaced I am still having the same issues. Now my local dealership is telling me that the wires for the sensor are being corroded at different places, yet the only way to know if it fails is once all the lights start to come.
I have had the vehicle fixed again today due to another part of the wire that corroded.
I have also been told that due to wear and tear of this 2 and half year vehicle 83000km there is nothing that can be done as it’s normal for any car.
If the issue does happen again, I am told that the entire wire harness would have to be replaced…..
I was always under the impression that these harnesses are protected from the elements/ harsh conditions for Atleast 5-10 years maybe longer before they begin to deteriorate.
Overall, just wondering if anyone else is facing these same issues.
10+ years for a wire harness is a valid expectation
I don’t know the area you live in but seems like the dealership should have done more for you - they are telling you it’s normal - I don’t believe that
I don’t know the area you live in but seems like the dealership should have done more for you - they are telling your it’s normal - I don’t believe that
Residing in Toronto Canada so salt is always an issue that being said, I have driven plenty of cars a lot older that had never had an issues like this.
Manager also said maybe it’s an Animal (squirrel) chewing on the wire
Yet I park strictly in the garage along with my wives car so, unless I have a mouse who loves the colour blue- I’m out of luck.
Rodent damage was my guess as well - check around the vehicle with a strong flashlight to look for evidence
Often rodents chew the wiring as a source to build a nest - a common place for the nest is the cabin air filter so pull out the cabin air filter and look there
One recent report on this forum the rodents got into the headliner
To see other owners reports search on this forum
Here’s a search for “rodent” but there’s also posts about mice, etc.
https://www.broncosportforum.com/forum/search/2226236/?q=Rodent&o=date
Diego
Ford Bronco Sport 2021
I had an issue with the ABS/EBB system in my BS 2021 after 25k miles. The local dealer diagnosed it and recommended replacing the part. The cost here in Brazil is about 3,000 dollars. This makes me question whether I should continue with a Ford vehicle. This kind of problem shouldn’t happen because an ABS module is not a component that should wear out over time.
Robins21
Horse Pasture, Virginia
bushbunnie
Al
Piney, Manitoba
2014 Ford F150 and a 2023 Bronco Sport
I have a 2023 BS Big Bend. I don't have any issues yet but it's a 1.5 not a 2.
izzyb20017
Isabella
Canton Ohio
ford bronco sport
I am having the same issue on my 2021 Big Bend. They initially thought it was a speed sensor, replaced that and noticed wire damage and then ordered me a new ABS harness which took over 3 months to arrive. To replace it, they had to take the entire front end of the car apart including the engine and my seats. I was told it was one of the first parts that Ford puts in when they assemble the vechicle. Following the ABS harness replacement, I am still having issues with different warnings coming on and my car is currently getting fixed because I was getting the "Brake applied, power reduced" error even though my brake was not being applied.
