SYNC 3.4 Navigation Map Update NA 2 25 Now Available with Instructions
thomasm23
Los Angeles Metro
There are many new features included in this update.
This is for 21-24 Sync 3.4 vehicles equipped with factory Navigation. If you have a 2025+ vehicle, you are running SYNC 4 and cannot install this update.
Before updating, make sure you are running Sync 3.4 Build 23188 or higher.
To check:
On center screen
Tap Settings
Scroll left or right to General
Tap General
Scroll down to About SYNC
Tap on About SYNC
If not, view link.
https://www.broncosportforum.com/forum/threads/sync-3-4-build-23188-is-the-current-version.11594/
Ford offers 3 years of navigation map update opportunities at no charge. Each download is a one time download. This means you can only download each year’s update one time. Each navigation map update, directly from Ford, is tied to the vehicle’s VIN.
This is my sixth update for my 21 OB. Ford is charging me $109 for the digital download. A preloaded USB version, includes a USB flash drive and shipping, is $149.
This update includes new maps and updated Gracenote version. To get this update use the following:
https://syncnavigation.com/ford/home
This is a large download to your Windows device or your Mac. Make sure you have a fast reliable connection. It may take over an hour to complete. My download took 2-1/2 hours. Make sure your device does not go into sleep mode. FOLLOW INSTRUCTIONS.
You will need a USB-A or USB-C flash drive that is 16GB or larger. The flash drive will need to be reformatted to exFAT. Make sure you are using a quality USB flash drive. Ford recommends a flash drive supporting USB 3.0 or higher.
FOLLOW INSTRUCTIONS and copy files to USB flash drive. This may take up to an hour. Mine took 20 minutes.
We may now be at 3 hours.
Time to update the vehicle. This may take an additional hour. Mine took 40 minutes. Plan when taking a long drive. The vehicle must be running the entire time.
Remove any USB cables from the ports.
Insert the flash drive in the ports under the climate controls. FOLLOW ON-SCREEN INSTRUCTIONS
Do not remove the flash drive. Do not turn off the engine. Follow on screen instructions.
This may take around an hour to complete. Your vehicle’s screen will restart multiple times. Do not remove the USB flash drive. FOLLOW INSTRUCTIONS.
Ford Bronco Sport SYNC 3.4 Navigation Map Update NA 2 25 Now Available with Instructions IMG_0269
Ford Bronco Sport SYNC 3.4 Navigation Map Update NA 2 25 Now Available with Instructions IMG_0270
Ford Bronco Sport SYNC 3.4 Navigation Map Update NA 2 25 Now Available with Instructions IMG_0271
Ford Bronco Sport SYNC 3.4 Navigation Map Update NA 2 25 Now Available with Instructions IMG_0273
Ford Bronco Sport SYNC 3.4 Navigation Map Update NA 2 25 Now Available with Instructions IMG_0274
Ford Bronco Sport SYNC 3.4 Navigation Map Update NA 2 25 Now Available with Instructions IMG_0275
My Nav Maps are now NA 2 25
thomasm23
thomasm23
Los Angeles Metro
Ford Nav seems hardly worth paying for when there are better free options and can download maps for offline use
$109 per year is actually cheap compared to other vehicle manufacturers. Most are charging $120+ per year.
https://www.cars.com/articles/what-automakers-offer-app-subscriptions-and-how-much-do-they-cost-520637/
https://www.autoknowledge.com/index.php/see-all-vic-updates/440-navigation-map-update-pricing-by-manufacturer
Ford no longer offers SYNC 3.4 on any new vehicle. This uses a local static based mapping system upgraded once a year.
Ford is utilizing SYNC 4 or 4A and Ford Digital Experience on all currently produced vehicles. These services utilize a fee based cloud navigation system.
PHRIOS
Paulo
ARAXA/Minas Gerais/Brasil
Thank you for bringing us this news about the update. However, it's not yet available for us here in Brazil. For those who have already updated, could you give us feedback on the improvements? Were there any layout changes?
thomasm23
thomasm23
Los Angeles Metro
The title of this post refers to NA 2 25. NA=North America
SA=South America
The latest SYNC 3.4 Navigation Map update for South America is SA 2 23
This was based on 2023 maps released in 2024.
