245/70/17 installed
AZ_BroncoBL
Joseph
Jeep/Acura
So with the 1” spacers on full lock it rubs slightly but it looks killer. I’m going to cut the pinch weld a touch about 5 inches up is all it needs. But what can I do to push the felt back and keep it there?
theres a post and someone by the name of FordBroncoLifts who has some pictures of the pinch weld cut and they cut a very small piece of the felt. Then put a screw into the felt to hold it into place. The screw was painted black afterwards.
Ford Bronco Sport 245/70/17 installed 474A5B0B-D270-49B0-91BC-76AC1E6350E7
Ford Bronco Sport 245/70/17 installed E1C0956F-09A0-4629-9AAB-DD6C4A42416D
Ford Bronco Sport 245/70/17 installed 089ADDBC-9A47-4609-99DC-644262B9D2EB
YFD_322
scott
NY
2021 Rubicon
PWM and 1” spacers. It’s very close to felt but good. The ride is a bit different but good. I think the tire noise is what makes it ride different
Ford Bronco Sport 245/70/17 installed 586482AE-FBA3-46A1-8F9F-430E3D7C3417
Ford Bronco Sport 245/70/17 installed 8FBC9AE1-A6C0-4BB8-A4C2-E3FD5830169F
Ford Bronco Sport 245/70/17 installed 57379DCA-0007-43B1-9AAE-6EC2D1A712A5
Ford Bronco Sport 245/70/17 installed 13F0ABD4-DBEE-4089-ABCB-A6B4640E1D99
Bluebaru
Good pics but NO WAY am I doing that! I would consider cutting back the flange (pinch weld) a little but to actually remove 6 of the welds is unbelievable!!!! At most I would cut back to the pinch welds but not remove any of them.
Looks like you may need these 1.5 inch flares.
Ford Bronco Sport 245/70/17 installed BE1DBE14-F74D-4195-A01F-75C3856172D2
Ford Bronco Sport 245/70/17 installed 92A09900-199A-4055-9AD5-966A75C9A653
I couldn't agree more with this. That flange is where two different parts of the structure come together to form the unibody frame. Without the welds holding them together it's no longer a "unibody," it's two separate parts. The different parts of a unibody frame rely on each other to provide strength for forces in different directions, but that only works if they are actually connected to each other. Without these welds the forces on one part cannot be transferred to the other. I'm afraid that eliminating these welds has compromised the structural integrity of the frame. How much and in what ways? Who knows?
If you never plan to take it off-road where the frame will experience significant bending and twisting forces you'll probably never notice the loss in structural rigidity. But then again, if you never plan to go off-road why do you need the ginormous tires?
Where did you get the spacers?
Ford Bronco Sport 245/70/17 installed 1648202348706
One more thing used car buyers will need to watch for.
Reactions: Jrl
compass crusher
Nathan
linktr.ee
Yep, yep I did. I did mean 235/70R17 - thanks for the catch, and it's been corrected. Confusing enough with all the tire sizes being discussed, my throwing out / typing a wrong size doesn't help.
Do you have a lift besides your stock?
