All Terrain Tire PSI
GoatsyBanks
Josh
New Hampshire
Going out to anyone running A/T 3 tires.
Since we are putting light truck tires on a compact SUV, What is everyone running for PSI?
I just had 245's mounted and they set them at 37 psi. There is almost no compression in the rear so I am considering taking thoes down a bit.
Ford Bronco Sport All Terrain Tire PSI 20211129_120234
I have 245/65/17's on my Badlands, I run 33 psi cold.
The tires have not had any strange wear or any other issues for 7200 miles.
GoatsyBanks
GoatsyBanks
Josh
New Hampshire
Keep in mind that for every 10 degree F drop in air temperature you will drop one psi in cold tire pressure.
My 32 psi 235’s will start the day at 30 psi when it’s 30 degrees outside. So I’ll drive into work a little easier in the corners.
By 5pm I’ll be back up to 50 F and 32 psi cold.
How’s that for OCD :’P
GoatsyBanks
GoatsyBanks
Josh
New Hampshire
After 7200 miles, that's good to hear.
The rear wheels have a little bit of negative camber to them so I was thinking I would rotate them at sooner intervals.
I rotate with my oil changes at 5k intervals.
