Where to run the harness for the Rough Country roof light bar.
drsnutz46
Danny
Nampa Idaho
So I saw a lot of questions regarding where to run the wiring harness for the Rough Country roof light bar. This is what I came up with after much consideration, first and foremost I'm not drilling holes in the roof of my brand new truck so being a retired race car fabricator this is what I came up with, once you mount the light bar bring the harness 180 degrees toward the front of the truck, then you can tuck the harness in right next to the A-Pillar trim piece and run it all the way down to the engine bay. Once in the engine bay there's an air seal where it seals off the cowl from air and weather, I simply cut the air seal down the center and tucked the harness inside all the way over to the drivers side then silicone sealed the weather seal and it drops the entire wiring harness right next to the battery, here's a picture of the finished install, if you have any questions please feel free to hit me up.
Ford Bronco Sport Where to run the harness for the Rough Country roof light bar. Resized_20211006_144541_9594
VirtualJMills
Jason
California, US
Did you still tap-into the appropriate wiring harness locations in the driver-side A-Pillar and under-dash areas, per the Ford install sheet?
Or was that a Badlands/First-Edition only pair of harnesses?
Benanza
Ben
NJ
Wire harness for roof lights or dash cam are for BL/FE only
drsnutz46
Danny
Nampa Idaho
No with the Rough Country light bar you only have 3 wires to worry about, positive, negative and the switch, connected pos. and neg. to battery and mounted the relay on a box next to the battery then ran the switch through the fire wall where the main wiring harness feeds through.
