- Thread starter
- #1
Does anyone know if there is a nudge bar/grille guard available for the Badlands with tow hooks in the front ?? The Rough Country nudge bar doesn't work with the Badlands....just curious, thanks
You have to remove to tow hooks; that is where the nudge bar connects. Can't have them bothDoes anyone know if there is a nudge bar/grille guard available for the Badlands with tow hooks in the front ?? The Rough Country nudge bar doesn't work with the Badlands....just curious, thanks
For the mechanically stupid is that easy to do and will it work on the Badlands if I remove my tow hooks ??You have to remove to tow hooks; that is where the nudge bar connects. Can't have them both
Yes you can remove the tow hooks and put the nudge bar.For the mechanically stupid is that easy to do and will it work on the Badlands if I remove my tow hooks ??
Did the front bumper have to be taken off?I had my tow hooks removed to install the rough country nudge bar. So far, it is the only nudge bar out as far as I know. Looking for something for the back bumper. Anybody know if anything came out yet?
Yes, The bumper did have to be taken off, I had it professionally installed by a Rough Country authorized Dealer. They had to drill two small openings into the bumper, as shown in the instructions. Note : The frame on the first edition was a little different from what they show in the instructions for the nudge bar . The shop had to make a custom piece that they welded to the frame because I didn't want them to make a hole into the frame itselfDid the front bumper have to be taken off?
Is the badlands frame similar as in they would have to make a hole in the frame?Yes, The bumper did have to be taken off, I had it professionally installed by a Rough Country authorized Dealer. They had to drill two small openings into the bumper, as shown in the instructions. Note : The frame on the first edition was a little different from what they show in the instructions for the nudge bar . The shop had to make a custom piece that they welded to the frame because I didn't want them to make a hole into the frame itself
Not sureIs the badlands frame similar as in they would have to make a hole in the frame?
Anyway you can post install instructions? I am hoping the bumper doesnāt have to be removed if you arenāt buying lightsNot sure
Hi, I don't have a copy of the instructions but you can probably find them online somewhereAnyway you can post install instructions? I am hoping the bumper doesnāt have to be removed if you arenāt buying lights
https://fordrangerlifts.com/shop/ols/products/nudge-bar-light-bar?fbclid=IwAR0P27LX5xxRUA_8OSK5afw0wpyoX91TThQ_dJdaT8srvRRquxvCnlVxJD4Does anyone know if there is a nudge bar/grille guard available for the Badlands with tow hooks in the front ?? The Rough Country nudge bar doesn't work with the Badlands....just curious, thanks
