New Jersey Anyone aware of gas pedal adjustments?
jofer
Easiest option: Try switching to eco mode. That will make the throttle respond a bit slower and smoother.
More generally, I think pedal commander works with the sport. It allows you to change the programmed throttle response / how the gas pedal behaves by temporarily altering the signal sent by the gas pedal. Usually, folks use it to make things more sporty feeling, but it works both ways. I haven't tried it, though.
Edit: I just realized you meant "the pedal sits too high", not "the pedal response is too high". Ignore must of what I said. I need coffee...
AndyMac204
Andy
you can try the different modes as stated by jofer. play around with the seating positions maybe?
MKohlman
Monterey, CA
Girls both say gas pedal is too high any input?
Ford has always been odd about pedal positioning on their vehicles. While I love my Fiesta ST for example, it was so notorious for the odd placement of the gas pedal in relation to the brake and clutch that a whole cottage industry popped up for ways to modify it (something I did myself early on).
When you state too "high", do you mean too far forward or the pedal needs to be closer to the floor?
If it is too far forward, there likely isn't any easy way to fix that as you'd have to try and find a way to "recess" the pedal into the footwell.
If it needs to be closer to the floor (which is what I think you mean) what you might try is a sport gas pedal cover (do an Amazon search). Most are designed to be a bit larger than stock and usually can be adjusted upward or downward a bit, but it likely would require some experimentation.
One thing to be very careful with is to not get any cover so close to the floor that it runs the risk of snagging a mat or sticking on the carpeting. They would be highly dangerous.
carpaymentkid
tim
cape may co nj
rapid red bronco sport
Yes UP and down is the issue Thank you for insight and safety info much appreciated !
