CHECK ENGINE LIGHT Always ON
Fossil
Ernie
ohio
wonder if this is related to the fuel l rmodule recall.
ScareCrow
Burl
Indiana
BS/Badlands
It says 0 Unrepaired Recalls . Will see what they say on TUE. meanwhile I'll not use the car.
It's your vehicle and certainly up to you. Based on the error code it's apparently just a sensor fault and the cylinder shut down feature may be disabled....this means the car will run but all three cylinders will be active and use normal fuel consumption it doesn't sound problematic.
benzarod
benzarod
Rodrigo
Buenos Aires, Argentina
Three days isn't terrible. Parts are limited and service is still learning their way
I just got back from the dealer, they said that they can't reproduce the issue cause the light is not ON anymore.... So I'm facing this intermittence issues....
Ask if they can put a monitor on your bronco of it happens again. It plugs in under the steering column. Then you drive under normal conditions and it captures any faults when they happen. Easier than trying to get a dealer to reproduce the issue
Fossil
Ernie
ohio
crap service imo. If the light was on when you took it in they cleared it and should have told what the faults were.
benzarod
benzarod
Rodrigo
Thought it was ALWAYS on?
Yes, It was always on, the Car dealer saw it when they admitted the car. They called me 2 days after saying they can't reproduce the issue and the light is off now. Even do I have FordPass message that shows the issue.
