Change location of digital speedo.
Ed
Wantage NJ
The speedo on my bronco is in the lower right of the screen. I would prefer it centered like the one in the picture. I can't figure out how to do it and the salesman doesn't know either. A little help would be greatly appreciated. Thank you.
Ford Bronco Sport Change location of digital speedo. IMG_20210325_205411872_HDR~2
stoopidrookie
What version of the Bronco Sport do you have? There are two different center screens, depending on the trim level. Outer Banks and Badlands have 6.5 inch screen in the instrument cluster. The Base and Big Bend have a 4.2 inch screen.
Ed
Wantage NJ
Badlands 6.5 inch screen.
On your wheel, to the right is OK and directional arrows. Hit
MENU
SELECT SCREENS (depress OK)
scroll up and down and you should have
CALM SCREEN
Calm screen should center your speedometer.
NOW PLAYING also does with the radio selection above it.
Ed
Wantage NJ
MENU
CALM SCREEN
Thank you
Thank you
Once you have I believe up to five or seven options selected, go back to the main screen. The next time you start up your vehicle you just use the OK toggle up or down to change screens. It will toggle through the options you selected. The one in your photo is for Trip settings
It goes over to the lower right when the cruise and speed system is active. When you turn of cruise (x button) the speed readout goes back to the middle.
Geelloo90042
Angelo
Los Angeles
2021 Ford Bronco Sport-Badlands
I would also suggest to turn off lane (lame) keep assist by pushing the button on the turn signal stalk.
