Scratched black piano trim
Bronclahoma
Oklahoma
Scratched the black piano trim when I rubbed a small oak branch rather than high center. The paint got rubbed, too. But, isn't scratched. I've seen some threads about this trim coming from the factory scratched, but has anyone dealt with removing scratches? I'm still in northern New Mexico, will deal with it when I get home.
GoatsyBanks
Josh
New Hampshire
I'm working on that. Gotta find something to try it on in case of swirling patterns.
Also looking into clear plastic vinal adhesive to cover.
Lots of small branches here too.
I know there are wraps for the pillars costing $250+
I could probably find the link if you want
ScareCrow
Burl
Indiana
BS/Badlands
Pillar Wraps
Draper
Central Ohio
Bronco Sport BL + BL, 2021 Ranger XLT Sport
I emailed these folks... https://www.theocdplug.com/
They said they are working on a kit for the Bronco Sport and it should be out within the next 2 weeks. I don't know if the price will be any better than that listed above, but worth looking into when they start selling their kit.
christopheru
The Great White North
I thought the whole purpose of piano black trim was to get scratched? :)
More annoying to me is the paint coming off of the trim around my sunroof. I haven't seen that since my 1990 subaru legacy lost shiny black paint by the chunk on the roof edge trim.
BayBrownBronco
Detroit
Ford Bronco Sport Badlands
I think the issue with this C-Pillar trim, is that it's not painted (I believe?) but is instead just molded black plastic. I like how that saves weight, and cost. But I'm also not keen on how quickly it shows 'spider-web' scratches. There's a simple solution: a mild polishing compound like Turtle Wax Premium Auto Polishing Compound. It's at car parts stores and on Amazon. Other similar products I'm sure, would work just as well. I use it on mine every couple months, then re-wax or re-apply spray wax over the panel. Problem solved.
rdc17
VA
As long as it's not too deep you can buff it out, mine came with a few marks when I took delivery. Buffed it all out, then weeks later I start seeing marks again even though I hand wash with clean microfiber towels. I've given up on it for this year, when I give it the spring detail after the winter I'll buff it out again and probably wrap it.
GoatsyBanks
Josh
New Hampshire
What's your go to for a compound
christopheru
Just washed the car. Dried it with a microfibre cloth after a synthetic chamois. It has two coats of Finish First polish on it.
Now I am a sarcastic bugger, so if sarcasm offends, skip the rest of this post.
You have been warned…
To get it better than that, I would remove it from the truck, clean it within an inch of its life, air blow it dry in industrial clean room conditions, and seal it in shrink wrap and put it away out of the uv light like it was some sort of rare first edition comic book, only to be viewed by robotically controlled arms on a screen.
Or, ya know, just drive the thing and enjoy it.
Told you I was sarcastic.
Ford Bronco Sport Scratched black piano trim 82ACDD42-A15B-4F08-9B60-FC73F4CEDEDD
So, how do I remove the trim safely without scratching it to prevent scratches? Asking for a friend.
christopheru
It is always best to over remove things. I would use an angle grinder and cut a good few inches around the edge of the trim to preserve it in its most pristine condition. This also allows for context as to where exactly on the Ute the trim once sat. That’ll do ya.
This whole thread now makes perfect Mike sense to me ,thanks brother for getting us squared up . Enjoy this forum , keeps me smiling.
