They're almost right up again the window. Have to put the window down a little to clean under them. Had the dealer put them on... afraid I'd put on them on crooked. I do like the look of them.Do we like them? Pretty easy to install eh?
Thank you thank you!They're almost right up again the window. Have to put the window down a little to clean under them. Had the dealer put them on... afraid I'd put on them on crooked. I do like the look of them.
So is used instead of or before a good wax?Applied my first coat of DIY ceramic using Meguiar's M27 pro ceramic coating. Went on easy buffed out easy. I was able to cover the entire vehicle before buffing it out. I can see and feel a big difference.![]()
As a good wax. Washed it thoroughly, it was a hot sunny day so I pulled it in the garage. Coated the entire vehicle first then used clean microfiber cloth to remove the excess and buff it in. Glows like new glass.So is used instead of or before a good wax?
I need that. Or something like it.As a good wax. Washed it thoroughly, it was a hot sunny day so I pulled it in the garage. Coated the entire vehicle first then used clean microfiber cloth to remove the excess and buff it in. Glows like new glass.
Yeah I think there are a lot of advanced products out there. My dad swears by Meguiar's, has been a gear head his whole life. I've just used their products, had great results, and maybe more importantly, I know how to use them. Not that it's a magic skill, more the fact I've used so many of their products I know what to expect. I'd say any product you are comfortable with makes a difference even with light dirt and mud. It gets bugs off faster etc.I need that. Or something like it.
ever hear of this?
https://thelastcoat.com/products/the-last-coat-tlc-standalone-bottles
Thanks man.Yeah I think there are a lot of advanced products out there. My dad swears by Meguiar's, has been a gear head his whole life. I've just used their products, had great results, and maybe more importantly, I know how to use them. Not that it's a magic skill, more the fact I've used so many of their products I know what to expect. I'd say any product you are comfortable with makes a difference even with light dirt and mud. It gets bugs off faster etc.
I had to order the pro series, came from southern Ohio pretty fast.
Autotoolworld.com they had the best prices.
Meguiar's also makes a spray ceramic I've found at local auto parts stores. So easy to use.
Again wash the car...SPRAY IT ON WET PAINT...then I use a microfiber to just spread it around evenly while wet, spray it off with a hose and dry the car like normal. May seem crazy but it sticks and does a nice job too.
After this worked so well I tried the pro ceramic. I may use the spray between summer and fall application.
What did you use for the blackout? Plastidip?We finished all we are going to do right now.
1. Window deflectors
2. Hood deflectors
3. Mud flaps front & rear
4. Fender flares
5. De-badged
6. Side molding
7. Tinted windows
8. Hitch plug
9. Blacked out letters front & back.
10. Black chrome bronco logo rear and. future sides.
11. Tire upgrade: Toyota Open Country A/T 245/60R18
Like what we did.
Hyper dipWhat did you use for the blackout? Plastidip?
That would be great. I hope one is in the works.Putting on 1 more item. Rear spare tire rack when it is available by Ford.
How does your front camera work? Do you have a switch to turn it on?Just add front camera and the dish app. To watch games while the wife shops
The screen is factory, I bought this dongle that plugs into the Apple car play and let’s you operate any android app don’t even need a phone. The camera I bought on Amazon it works through WiFi so you don’t need to hook any camera feed to monitor. The power for the camera is hooked to a remote also from Amazon with a key fob that is hooked to the battery so no wires need to go inside. Very easy hookupHow does your front camera work? Do you have a switch to turn it on?
does it come through the screen or have you installed a separate screen also.
