Auto Start/Stop Disabled?
If you are in sport mode, it is disabled.
According to the owners manual, it gets enabled after the following conditions are met:
The system is enabled every time you start your vehicle if the following conditions are
met:
• You do not press the Auto-Start-Stop button.
• Your vehicle exceeds an initial speed of 3 mph (5 km/h) after the vehicle initially starts.
• Your vehicle is stopped.
• Your foot is on the brake pedal.
• The transmission is in drive (D).
• The driver door is closed.
• There is adequate brake vacuum.
• The interior compartment has cooled or warmed to an acceptable level.
• The front windshield defroster is off.
• The steering wheel is not being turned.
• The vehicle is not on a steep road slope.
• The battery is within optimal operating conditions, such as battery state of
charge and temperature in range.
• The engine coolant is at operating temperature.
• Your vehicle is not being driven at a high altitude.
• The ambient temperature is moderate.
Picky Bugger ain't she :'P
johnardsg
johnard
Texas (previously from PNW)
2021 BS BigBend/2011 v6 Rav4
met:
I like mine off all the time, sport mode all the time hehe
Mellow
Carrollton, TX
2019 Ranger/2012 Miata
In the Ranger, there's a plug to the negative side of the battery that some have un-plugged and it stopped the SS feature. It's the battery management feature and basically disables the SS feature if it detects your battery is low. Disconnecting basically tells it it's always low and disables it. It looks like there is a plug/clip attached to the neg battery that might be similar.
DakotaTimber
DakotaTimber
North Dakota
BS BL + BL, 360+, tow +
If someone does this, please post a picture.
So all we have to do is disconnect plug at battery and annoying start stop is disabled?
Mellow
Carrollton, TX
It monitors your battery so it won't stop then not have enough juice to start again, leaving you stranded in traffic.
There are some on the ranger site that have done this for months with no issues.
Reactions: Jrl
fourthgear
florida
That silver square with the Bar Code , where its plugged into ,almost looks like a Relay. Might be some kind of Logic board , but the SW on that bar code may be a clue or just a Ford designation , interesting .
Reactions: Jrl
Bill did you try this yet?Sounds like it will work.
That Is it. Thanks
Ford Bronco Sport Auto Start/Stop Disabled? 51C73A7F-4B90-4C1E-8529-9CACA139FABB
johnardsg
johnard
Sorry folks i might have done it wrong earlier but i tried removing that wire and this is what i see in the screen.
Ford Bronco Sport Auto Start/Stop Disabled? 3ABF3881-F4D0-4073-8602-06CC6DCAC69C
Mellow
Carrollton, TX
Well, worth a shot. When forscan is available that can be used. Sorry for not providing a similar result as the Ranger, sure looked like the same setup.
