Disable Backup sensor beep
Penker
Bronco Sport OBX
For the purposes of attaching a bike rack or just about anything to the hitch...how can I silence/disable the backup beep?
SLJ
Elbridge NY, USA
Bronco Sport OBX
From the manual:
Note: When you connect a trailer to your
vehicle, the rear parking aid may detect the
trailer and therefore provide an alert. Disable
the rear parking aid when you connect a
trailer to prevent the alert.
The sensing system warns you of obstacles
within a certain range of your vehicle. The
system turns on when you switch the
ignition on.
You can switch the system off through the
information display menu or from the
pop-up message that appears once you
shift the transmission into reverse (R). See
General Information (page 98). If your
vehicle has a parking aid button, you can
switch the system off by pressing the
button. The system turns on when you
switch the ignition on.
shakeandbaker
Austin
Cactus Gray BS Badlands, BMW 135i
Wondering if there is a way to do this too. It can be turned off temporarily, but doesn’t seem like it can be turned off permanently. Haven’t found a way to do this with ForScan yet either.
jazzdab
Thom
Raleigh, NC
From the touch screen under Settings -> Driver Assistance -> both Park Aid and Rear Cross-traffic alerts can be disabled.
I use the dash pop-up to temporarily disable alerts (by pressing OK on the steering wheel) when backing into my garage.
