245s and fenders
schizorage
Brian
Southwest Ohio
2021 Bronco Sport Base
For anybody who is running 245s on the factory offset 17s, does the outmost tread extend outside the fender well? I'm not planning on changing my wheels, I really like the base model's, but I don't want to throw gravel all over my own car.
Let me know, please and thank you!
Huntyeraws
Nick
Rochester, NY
2021 Ford BS BB
If it does, I am figuring that it can't be that much, the 245's are only 0.7" wider across than the factory 225's. Divide by 2 and only 0.35" wider sticking out. If concerned, get the splash guards. Likely what I will do with my BB when I get it.
Ford Bronco Sport 245s and fenders Tire comparison
Stitch50
AK
NH
Ford Bronco Sport / Ram 1500
Here’s my base with the 245’s. They really don’t stick out much at all. This isn’t a great side angle, but hopefully this helps.
Ford Bronco Sport 245s and fenders C70634E0-F217-444C-9487-87E945612B7D
schizorage
schizorage
Brian
Southwest Ohio
It does, actually. Most of what I've seen have been tires with more aggressive edges, this eases my mind. I don't want to add mudflaps because of the drilling involved, and the Wildpeak trails I'm using have a more subdued edge. Between your example and the tire size comparison diagram I think I'll be ok.
Thank you both!
tRex
Rochester, NY
...and even less of a difference from the 235's (BL option) that are installed without any wheel or fender modification needed.
Huntyeraws
Nick
Rochester, NY
2021 Ford BS BB
yep... 0.3" total width difference, divided by two is 0.15" wider on the outside over the 235's.
schizorage
schizorage
Brian
Southwest Ohio
True, but mine is a Base, with the 4wp leveling kit forthcoming.
Huntyeraws
Nick
Rochester, NY
2021 Ford BS BB
Your BS base body is the exact same width as the BL and other BS models.
schizorage
schizorage
Brian
Southwest Ohio
True, the track width doesn't change. It's nice to have one's mind eased. I really dig this little trucklet.
