2021 Bronco sport base Lower control arm removal - pass side front.
Chambr
Having a bitch of a time getting this control arm out ... appears that a bolt that is supposed to go thru the arm is covered by a box frame of sorts ... cant even see a bolt in there (althought there has to be) ... took as much apart as i could think of and yet no movement ..... If theres a trick i am missing let me know
-Mike-
Ford Bronco Sport 2021 Bronco sport base Lower control arm removal - pass side front. 05755e68-55ee-48f5-93dc-52eb8aa476ed
Ford Bronco Sport 2021 Bronco sport base Lower control arm removal - pass side front. 9344c839-4da8-407a-9aea-5496289f125f
Ford Bronco Sport 2021 Bronco sport base Lower control arm removal - pass side front. bb1ece5b-0b4c-46c1-b570-f9d038f9823
Ford Bronco Sport 2021 Bronco sport base Lower control arm removal - pass side front. c59e5dc3-373f-4ef7-b203-3b883ac378f
Ford Bronco Sport 2021 Bronco sport base Lower control arm removal - pass side front. de23874f-db54-463c-9664-0ab88696fcaf
-Mike-
In your last photo the outer side member is still in place
Did you remove the front cross member so the outer side member can be removed.
In the photo I see you have 3 of the 4 bolts removed that attach the outer side member.
Once the outer side member is removed you will have access to the "captive bolt head"
Chambr
TY TY .. Will give it a shot tomorrow .... (front cross member seems like it will be the ticket) Just couldnt wrap my head around it ....
