Coolant before and after do I need to take this 2024 bronco sport Big Bend to the dealer asap?
topspin34
topspin34
William
Chattanooga, TN
2024 Ford Bronco Sport
The first picture is when It had been sitting for about 3 hours The second picture is after driving about 30 mi immediately after parking
Unfortunately the coolant level looks low. You can fill the coolant resovoir to a more normal level and keep an eye on it.
More likely than not your Sport has a coolant leak and usually it's the water pump. If your vehicle is still under warranty take it to the dealer so they can make it right
topspin34
topspin34
William
Chattanooga, TN
That's what I was thinking. I just always like to get a second opinion. Thank you for the response.
Roxyy
NYC
My coolant was low out of nowhere and I took it in and they couldn't find anything. I took it back again a month later, and they found that there was coolant in two of the cylinders and had to replace the engine.
Few months later, had the transmission changed (for a different issue) and got it back with my coolant below minimum again. I'm dreading bringing it back. 😩
topspin34
topspin34
William
Chattanooga, TN
Yes most Ford dealership service departments are friendly helpful and want to make things right. Unfortunately there are some out there who get an attitude especially if you are somewhat educated on the known issues with the Bronco Sport. I know someone who experienced this and it was difficult to get them to do anything other than the bare minimum and they constantly said they couldn't find anything or there was nothing else they could do etc. I think he went to another Ford dealer and they made him feel like He needed to go back to the original dealer since that's where he started.
rickg121
Richard
2024 Bronco Sport
Funny that you should bring that up. My 2024 ( 22k miles) is parked at the dealer with engine misfire (cylinder 1&2) warning light and low coolant. They've had it for a week now. Conventional wisdom would indicate a bad head gasket or cracked head or block. We'll see. In the meantime, they gave me an Edge as a loaner. Not quite the same.
Roxyy
NYC
Oh no! 😩 Hopefully they can figure it out soon. My car was stuck at the dealership for over 30 days when they replaced the engine due to cracked engine block... and when I got it back, there were even more issues that they never fixed in the end. 😢 Going to a different dealership soon. Hopefully your dealership is better than mine was!
