I lost my center dash options!
smcBronco
Sean
Ocean Shores, WA
Ford Bronco Outer Banks, Alfa Romeo 4C, Smart for two
Like the title says, and I no longer get the screen to customize the options. It happened today when I switched to 4 wheel drive only mode for a ride on the beach.
I tried switching back to Normal, Eco, and Sport; but no luck, the Trip 1, Trip 2, and other screens are gone!
Any ideas?
hcrews1955
Hilton
Purlear, NC
I think you need to keep going with the up button (watch the blue bar on the right). Hold the configure screen and then select which item you want displayed. Hope this helps.
smcBronco
smcBronco
Sean
Ocean Shores, WA
I tried that. Also tried switching to different GOAT modes, no luck.
2025 Badlands Sasquatch
Seems to be a lot of misbehaving dash displays. Mine (‘25 BL SAS) has reverted to the factory settings at least three times in the last three months. Minor issue to return it to my preferred settings, but still…
rugedraw
Javier
Miami, FL
Did it come back? Did you try a Sync reset by holding down the radio power button and forward seek button on the steering wheel with the vehicle running until the screen reboots?
smcBronco
smcBronco
Sean
Ocean Shores, WA
No, I never heard of that. I'll try it and report back!
smcBronco
smcBronco
Sean
Ocean Shores, WA
Ah, no luck. That reset the Large Center screen. My issue is the the center of the dash, between the tach and speedometer. I lost my Trip 1, 2, MPG, and the screen to pick which views show.
smcBronco
smcBronco
Sean
Ocean Shores, WA
Yes, I've tried that as well. It will only show the 3 views like in my video.
rugedraw
Javier
Miami, FL
Yea, I getcha. But on the 2025 models, the IPC is managed by the APIM, so it won't hurt to try. That you know of, did the vehicle receive an OTA update recently?
If you have FORScan, I would try going into the IPC, APIM and GWM procedures under the wrench icon and reboot all three modules. If you don't, then I would try disconnecting the negative cable from the 12v battery and reconnecting it. This is will force a hard reset of the module network.
smcBronco
smcBronco
Sean
Ocean Shores, WA
I found my problem. I was not in "My View". When I opened the menu and went to settings, I was at the bottom of the settings list. I had to scroll up to see the option "My View. "
