Oil Life Screen not showing up anywhere - BS WT 20222
bucephaluz
Nico
Patagonia, Argentina
Ford Bronco Sport 2.0 Wildtrak 2021
Hello everyone!
I just bought a Bronco Sport wildtrak 2021, I’m really happy with the car so far.
however I can’t find the oil life information. I have navigated the center dash using the steering controls while the car is on but engine off and I can’t find the screen. I scrolled up and down on every screen and nothing.
feels like I’m missing screens. My dash has the bigger screen. It doesn’t have the needles gauges for gas and temperature.
i get into settings screen using the steering wheel controls and that screen is empty! Nothing showing if I scroll up or down.
anyone else with this issue?
thanks you and greeting from Patagonia!
Nico.
This is from the owners manual:
Maintenance - Oil Change Indicator Reset
Ford Bronco Sport Oil Life Screen not showing up anywhere - BS WT 20222 {filename}
Use the information display controls on the steering wheel to reset the oil change indicator.
From the main menu scroll to:
Message​
Action and description
Settings
Press the right arrow button, then from this menu scroll to the following message.​
Vehicle
Oil Life
Hold OK to Reset
Press and hold the OK button until the instrument cluster displays the following message.​
Reset Successful​
When the oil change indicator resets the instrument cluster displays 100%.​
Remaining Life​
{00}%​
If the instrument cluster displays one of the following messages, repeat the process.​
Not Reset​
Reset Cancelled​
thomasm23
Los Angeles Metro
Try this.
On the steering wheel right side:
Press the MENU button.
Scroll up or down with the OK button.
Select SETTINGS.
Press OK
Oil Life will appear.
Press OK
Press BACK to exit.
Ford Bronco Sport Oil Life Screen not showing up anywhere - BS WT 20222 IMG_4961
Reactions: Me3
PugDad
Bronco Lilly
Newfoundland,Canada
BSBL
Owners Manual, what a novel idea.
bucephaluz
Nico
Hello everyone!
Nico.
screens for reference
Try this.
Select SETTINGS.
Press OK
Press OK
Press BACK to exit.
i already tried that… the settings menu is empty, it’s not showing anything. I scroll up and down and nothing shows up.
Message​
Settings
Vehicle
Oil Life
Hold OK to Reset
Reset Successful​
Remaining Life​
{00}%​
Not Reset​
Reset Cancelled​
Nope, nothing is showing up. The settings menu is empty, blank, no options, nada.
Reactions: Me3
2025 Badlands Sasquatch
Without knowing what the SA market builds are supposed to include, the NA owner's manuals aren't going to be of much use. I'd suggest OP get the manual for their market online if it's not still with the vehicle.
Reactions: Me3
bucephaluz
Nico
I do have the local market manual, but it’s not showing what it says it should show.
From Patagonia, I believe the nearest dealer to you is Pedro Corradi in Chubut, so I'll go out on a limb and guess that's not a great option.
For the smarter minds here, would a reset of the ECM/PCM also reset gauges and displays?
Reactions: Me3
I just checked the oil life on my 2021 Badlands, it is at 95% as I just had it serviced July 19th.
I did it with my vehicle running.
On the steering wheel.
1. Press the menu button
2 . Press the ok button
3. Scroll up or down if needed with the ok button to select settings.
4. Press ok button
5. Oil life will be displayed
Typically I monitor the oil life using FordPass as well as look at the mileage and checking the dipstick.
Reactions: Me3
thomasm23
Los Angeles Metro
What Build version of SYNC 3.4 do you have installed?
On the center screen:
Tab SETTINGS
Swipe left or right to General
Tap General
Scroll down to About SYNC
Tap About SYNC
Also, have you ever selected any screens to view from the MENU button on the steering wheel?
Reactions: Me3
bucephaluz
Nico
4. Press ok button
The image I posted above is what I get if I follow these steps. The settings (ajustes in Spanish) screen is empty.
Reactions: Me3
bucephaluz
Nico
Tab SETTINGS
Tap General
Tap About SYNC
I can navigate and see all the other screens. Tires, seatbelts, trip1, etc… oil life screen isn’t there :(
Reactions: Me3
thomasm23
Los Angeles Metro
Do you see either one of these screens?
Ford Bronco Sport Oil Life Screen not showing up anywhere - BS WT 20222 IMG_4962
Ford Bronco Sport Oil Life Screen not showing up anywhere - BS WT 20222 IMG_4963
If you scroll down the SETTINGS menu will appear. Pull and hold the OK button until SETTINGS appear.
Reactions: Me3
bucephaluz
Nico
@thomasm23 i do see all those screens but under settings it’s all empty, no options at all. I scroll up and down but nothing shows up.
Reactions: Me3
