More RDU issues
Major Kong
Major
Right Here Right Now
Bronco Sport aka "Spark Plug"
I don't believe the 2011 Edge was ever intended to be driven off-road like the Bronco Sport.
the one thing that did flag my interest
the housing appears to have a sloped trough at the vent on this unit
almost as if someone knew the potential existed for water intrusion
the video poster mentioned "puking gear oil"
but my thoughts are that it was not for gear oil barf
Major Kong
Major
Ford Bronco Sport More RDU issues 1743514494186-g9
TY Mark!
this is what I had been searching to find
if this is the case (pun)
the dual vent application on the fire wall is back to the drawing board
relieved to see there just may be a properly positioned case vent
bonus pic
drain plug
will need to confirm this upcoming oil change
Ford Bronco Sport More RDU issues 1743515090474-8s
Major Kong
Major
oil change (engine) complete
PTU drain plug confirmed (previous post check list)as present
it's a good day
Nikki
Nikki
Chattanooga, TN
Mini cooper
My mechanic diagnosed that I do need the new vent hose. At the time he said it was on backorder so we went ahead and changed the rear differential fluid. But that only improved the shuttering slightly. Would that indicate that I need to have the rear differential unit replaced? I’m 24,000 miles out of warranty. So I’m out of pocket. Any advice is appreciated.
I can not stand dealerships. This is my first and probably last Ford!
mxATVracer10
Derrick
Sapulpa, OK
2021 BS/BL, 2013 Fusion SE, 2004 F-150 FX4
rubber hose extensions
that's all it amounts to
recall similar modification applied to high pressure fuel pump leak
sorry mr kong
we'll put you on a list
that response was almost a year in the making for a remedy
these rubber hoses
rare as a unicorn
kong solution
remove terminal screen from existing hose
add rubber hose purchased from corner hardware store
sleeve and shrink wrap connection point of old to new
insert screen into new section of rubber hose
good to go until parts come in
If the issue is merely the vent location as it appears, I don't see why extending and rerouting the current hose wouldn't be an easy solution.
Mr. Kong, do you recall what size hose this modification requires?
Major Kong
Major
my memory files are corrupted
Major Kong
Major
apology for the delayed answer
recently found the removed section of hose
also with it a portion of the new hose material
old vent hose material - rubber 5/16" ID
new extension length +/- 4 feet of rubber 1/4" ID vacuum hose
point of connection was at the wheel well plastic 90 degree bend
removed the small wheel well segment of original vertical vent hose
just enough room to squeeze new tubing up into rear light cavity
snug fit but air movement unhindered
wire strapped to passenger side rear light (far left side of light)
just behind light beneath plastic fascia
removed vent poppet from original (removed) segment
installed poppet on terminal end of new hose - snug fit applied light grease film
total time less than an hour
mxATVracer10
Derrick
Sapulpa, OK
Much appreciated! 😎👍
