2022 Badlands Sensor Issue
AmyH87
Louisiana
Ford Bronco Sport 2022 Badlands Sensor Issue IMG_6020
Ford Bronco Sport 2022 Badlands Sensor Issue IMG_6021
Can anyone tell me exactly what sensors need to be replaced? I do not wanna have to bring my car to the dealership however, the mechanic said he cannot tell what sensors exactly they are. Maybe I’m silly for asking this. I’m clueless when it comes to this stuff lol
ScareCrow
Burl
Indiana
BS/Badlands
If it's still under warranty, take it in for a check up!
What problems are you having or are you just trying out a new tool?
HotRod4321
Rod
Alpharetta GA
2024 Ford Bronco Sport Big Bend Chille Red
Unfortunately, you will need to trouble shoot to find the 'short'/problem. Start by turning the drive and goat switches (do you use them a lot? Too much? could a switch have gone bad? Or maybe never using the goat mode switch? Maybe just cycling them will help.), alternately, is there a bad connection/s that may have gotten water in them. I have solved some electrical issues just by taking the quick disconnects apart and then back together. And then, sadly, the PCM may have gone bad, shorted? UGH! Good luck in your journey and let us know how it went!
What is OBD-II Code P05D2 – Driver Mode Select Switch A Circuit High?
The OBD-II (On-Board Diagnostic) system is an automotive diagnostic system that monitors and regulates the engine functions of modern vehicles. Vehicle manufacturers implemented the OBD-II system to improve fuel efficiency, reduce emissions, and make repairs easier by allowing mechanics to read diagnostic trouble codes (DTCs). DTCs are codes stored in the vehicle’s memory that indicate a fault in one of the monitored systems. One particular DTC that mechanics and vehicle owners might encounter is the P05D2 code, which indicates a circuit malfunction in the Driver Mode Select Switch A.
The Driver Mode Select Switch A is part of the car’s powertrain control module (PCM) and allows the driver to switch between various modes of operation. In particular, this switch is responsible for selecting the mode of operation that focuses on fuel economy as opposed to performance. The PCM uses the switch signal to adjust engine behavior and improve fuel efficiency. When the PCM detects a circuit malfunction in the Driver Mode Select Switch A, it triggers the P05D2 code, indicating a problem with the circuit.
Symptoms of OBD-II Code P05D2 – Driver Mode Select Switch A Circuit High
One of the most common symptoms of the P05D2 code is the illumination of the check engine light on the vehicle’s dashboard. Additionally, the driver may observe that the fuel economy has decreased, and the engine is not running optimally. This may also result in a lack of power, slower acceleration, and difficulty shifting gears. Other possible symptoms of the P05D2 code include overheating or stalling of the engine.
Causes of OBD-II Code P05D2 – Driver Mode Select Switch A Circuit High
The P05D2 code can be triggered for various reasons, such as:
1. Electrical problems within the circuit: When the circuit is compromised, the PCM cannot read the signal from the switch, and the P05D2 code is generated as a result.
2. Defective switch: The switch might be faulty, sending incorrect signals or failing to send signals at all, resulting in a malfunction.
3. Poor wiring or connections: Faulty wiring or connections can disrupt the signal path between the switch and the PCM, leading to the P05D2 code.
4. PCM problems: The powertrain control module (PCM) might be faulty or damaged, causing it to misinterpret the signal from the switch, resulting in the P05D2 code.
Diagnosing OBD-II Code P05D2 – Driver Mode Select Switch A Circuit High
The P05D2 code is typically diagnosed by using an OBD-II scanner tool. The tool plugs into the vehicle’s diagnostic port and reads the code stored in the PCM. Once the code is retrieved, the mechanic will begin to diagnose the issue. First, they will check the electrical connections and wiring for damage, corrosion, or other signs of wear. Afterward, they will inspect the switch itself to ensure it’s functioning correctly. If these inspections do not reveal the issue, the mechanic may then proceed to diagnose the PCM for faults.
Repairing OBD-II Code P05D2 – Driver Mode Select Switch A Circuit High
Repairing the P05D2 code most often involves replacing the switch, fixing electrical connections or replacing the PCM. Here are some of the steps involved in repairing the P05D2 code:
– Replace the switch: If the switch is faulty, the mechanic will replace it with a new one. They may need to remove some trim components to access the switch.
– Repair poor wiring or connections: If poor wiring or loose connections are causing the issue, the mechanic will repair or replace the affected parts.
– Replace the PCM: If the PCM is defective, the mechanic may replace it with a new one, which may need to be programmed to work correctly with the vehicle.
FAQs on OBD-II Code P05D2 – Driver Mode Select Switch A Circuit High
1. Can I continue to drive with the P05D2 code?
It is not recommended to continue driving with the P05D2 code because it can lead to engine problems and reduced performance. It is best to have it fixed as soon as possible.
2. How much does it cost to repair the P05D2 code?
The cost to repair the P05D2 code depends on the extent of the problem. Replacing the switch is relatively inexpensive, while replacing the PCM can be more costly.
3. How do I prevent the P05D2 code from occurring?
Regular maintenance and inspections can help prevent electrical problems that can lead to the P05D2 code. Additionally, being mindful of driving modes and switching between them correctly can help prevent the switch from malfunctioning.
4. Can I fix the P05D2 code myself?
It is not recommended to repair the P05D2 code without proper knowledge and tools. It is best to take the vehicle to a certified mechanic who can properly diagnose and repair the issue.
5. Can the P05D2 code cause other issues?
Yes, the P05D2 code can lead to engine malfunction or failure so it is best to get it fixed as soon as possible to avoid further issues.
Conclusion
In conclusion, the P05D2 code indicates a circuit issue with the Driver Mode Select Switch A. This switch is responsible for choosing the fuel economy mode of operation, and when compromised, it can affect the engine’s overall performance. The causes of this code vary, and diagnosing the issue involves using an OBD-II scanner to retrieve the stored code. Repairing or replacing affected components can fix the issue, and it is not recommended to drive the vehicle while the P05D2 code is present. Proper maintenance and being mindful of driving modes are great ways to prevent this issue from happening. Overall, if you are experiencing this issue, take your vehicle to a certified mechanic for proper diagnosis and repair.
What is OBD-II Code P05D2 - Driver Mode Select Switch A Circuit High • OBD II Code
Fortunately or unfortunately depending how you look at it, the best way to have the issue diagnosed is to take your Sport to a dealer, they have the software that can talk to whatever modules are involved with the codes you see, to find out whats causing the problem, otherwise you're just guessing.
In the mean time, does your battery currently have a low state of charge?
Have you or anyone spilled any liquid around the drive mode selector switches?
Have you tried resetting the code to see if it comes back.
There have been a few here that have had the mode switch go bad and had to replace it.
Someone even had an issue when a hair scrunchy worked its way under the shifter dial.
