Rear quarter filler panel..
keso151
kelly
minnesota
2022 bronco sport big bend
On our 2022 bronco sport I jackknifed a small trailer and cracked the passenger side filler panel. I have to remove that now. Has anybody done that or have a detailed removal process I can’t find anything online…
elvisimprsntr
Elvis
'25 BS BB
keso151
kelly
minnesota
Thank you, but I don’t wanna buy the whole manual just to remove one tiny panel in the back. It’s the filler panel. that is below the side window and above the bumper cover on the quarter panel. Just need to know the process to remove it.
By the taillight? Seems very involved. It looks to be a step in the complete bumper cover removal. You need to take off the taillights and the wheel trim if that one button connector holds it too. It does appear to be "under" the wheel trim layer.
Ford Bronco Sport Rear quarter filler panel.. 1747880248698-p3
Ford Bronco Sport Rear quarter filler panel.. 1747880006564-e1
Ford Bronco Sport Rear quarter filler panel.. 1747879765115-on
Ford Bronco Sport Rear quarter filler panel.. 1747879811202-87
Ford Bronco Sport Rear quarter filler panel.. 1747879845274-rv
Quashish
Tomas
Sacramento
2024 Bronco Sport Badlands
If it is just the plastic wheel arch, there's only like 4 white clips like those @Glamdring70 pictured (looks like more though) and one 7 or 8mm screw holding it on. Other than that you should be able to rip it off and new one should install very easily.
I've had to partially mess with that wheel arch to remove rear bumper cover. Doing so neatly under the wheel arch is the hardest part.
I'm just not Sure what "filler panel" refers to
keso151
kelly
minnesota
What panel exactly? Pictures please
I guess it’s called the rear bumper and it’s next to the tail light below the window above the arch. It’s a little triangular piece of ABS plastic… number four in that picture on my 22 bronco sport
Ford Bronco Sport Rear quarter filler panel.. IMG_2366
Ford Bronco Sport Rear quarter filler panel.. IMG_2367
keso151
kelly
minnesota
