Hood Deflector = Hood Bounce / Flapping
Humper
Mick
Oklahoma
Well, I got the hood vibration mostly gone, the 1/4” fuel pipe helped a bit, the other thing that helped much more was using high temp epoxy and glueing aluminum bracing pieces under the hood, the vibration, it looks a bit ugly right now, I plan on painting those areas with flat black paint and I also have the under-hood liner, do won’t see the pieces.
bdewey
Washington State
Moving from Mazda CX-5 to Bronco Sport in a week
Letting the Dealer install mine next Thursday. If I get the "bounce" or vibration, it will be up to them to fix it.
Lynn
Mesa, AZ
2024 Bronco Sport Free Wheeling and 2008 Ford Mustang GT/CS
well. I was going to go buy this for my new Bronco and y'all have scared me off from it.
maybe I can get it installed by the dealer and be safer.
tommy
tom
I tried the 1/4" fuel line, and adjusting the 4 bumpers, it did help a little bit. I'm going to order 5/16" on Amazon as a final try.
rorlow
Ron
Detroit MI
I used the 1/4" fuel line in mine, the 5' length is right size and just trimmed couple inches off one end and completely installed. Little trick is to spray a small amount of silicone spray inside the OEM weather seal. I left about 1/2" longer on each side in the event I need to remove down the road. I also turned up the hood bump stops couple turns. Will update once I take it out on the freeway at 70-80mph.
Ford Bronco Sport Hood Deflector = Hood Bounce / Flapping IMG_7297
tommy
tom
I tried the 5/16" but it would only go in about 2'. A little Dawn soap on the 1/4"-no problem. I also tightened all 4 hood bumpers. Seemed to help on the interstate.
CancunBadlands
CancunBadlands
Cancun, MX
What 4 bumpers?! I don't see any under my hood, 2023 BS BL, do you mind to post a picture?! #TY
CancunBadlands
CancunBadlands
Cancun, MX
As I said what all 4 hood bumpers?! I only see 2 bumpers on the rear hatch door, not under the hood... #OMG
CancunBadlands
CancunBadlands
Cancun, MX
2 next to the radiator and 2 attached to the hood.
Ford Bronco Sport Hood Deflector = Hood Bounce / Flapping IMG_1711 (002)
Ford Bronco Sport Hood Deflector = Hood Bounce / Flapping IMG_1712 (002)
TY pal! I just went outside and open the hood! I see what you're talking about!
Ford Bronco Sport Hood Deflector = Hood Bounce / Flapping 20250514_173028~2
DWG
New Jersey
Mine has been on for over 4 years on my First Edition 2021 . No issues.
Just guessing but I am betting that being a first edition your BS has the under hood weatherstripping on the sides of the hood. They just snap into the holes along the underside edge of the hood. I do not know what year they were deleted but they were deleted from my BS. I had some questions for the shop Forman under the hood and he saw the weatherstrips and said I was smart to add them. He said they would help with hood vibration. I don't know if they would help with vibration from adding the hood deflector since I do not have one but at about $25 for each side they may be worth a try.
Hood Hinge Seal Weatherstrip - Left side Part #: M1PZ16A239A
Hood Hinge Seal Weatherstrip - Right Side Part #: M1PZ16A238A
CancunBadlands
CancunBadlands
Cancun, MX
I don't have those neither... oh Gosh! 2023 BS BL
kshaw
Kent
Gaithersburg, MD
As DWG suggested, I installed the two weather strips on my hood shortly after I got the BS. There is no vibration or looseness. This mod will likely solve your problem. I also got the Ford hood soundproofing. This part had a very hefty shipping cost which was waived if you order from your local Ford dealer and pick up at the dealership. The installation was very easy.
