Rear Window Washer
Andrezzi
robert
PA
is there a separate pump for rear window washer front ok nothing spraying on rear window ?
Davexxxx
MO
2024 Bronco Sport, 2023 F150 Powerboost 501A
There is a separate switch for it.
Andrezzi
Andrezzi
robert
PA
I know but nothing spraying when activated did work previously. Fluid full front working is it work from same pump. don't see any leaks.
Davexxxx
MO
I suppose there could be a single pump, with a diverter and check valve but could also have 2 pumps, sharing the same reservoir.
A call to the parts counter, would answer the question.
mbeckm
PA USA
to ChatGPT:
FORD BRONCO SPORT: is there a separate pump for rear window washer - front ok BUT nothing spraying on rear window ?
ChatGPT said:
The Ford Bronco Sport (like most modern vehicles) typically uses a single washer pump that supplies fluid to both the front and rear washer nozzles. The pump changes direction or uses a valve to direct the fluid to either the front or rear when you activate the respective switch.
Possible Reasons Your Rear Washer Isn’t Working:
  1. Clogged Nozzle – The rear washer nozzle may be blocked with dirt or debris.
  2. Frozen or Clogged Hose – If it's cold, the fluid line may be frozen. Otherwise, the hose could be pinched or clogged.
  3. Disconnected or Damaged Hose – The hose running to the rear may have come loose or developed a leak.
  4. Malfunctioning Pump Valve – If the pump isn’t switching correctly, it may not be sending fluid to the rear.
  5. Low Fluid Level – If the fluid is too low, the pump may only be supplying the front.
How to Fix It:
✅ Check the rear nozzle – Use a pin or needle to clear any blockages.
✅ Listen for the pump – When you activate the rear washer, can you hear the pump running? If not, the pump may not be switching properly.
✅ Inspect the hose – Look for any leaks or disconnections near the rear hatch.
✅ Try a different washer fluid – If it’s cold, try a winter formula to prevent freezing.
If the front washers work but not the rear, it’s likely a clogged or disconnected line rather than a pump failure. If you need help locating the hose or nozzle, I can guide you!
Andrezzi
Andrezzi
robert
PA
to ChatGPT:
How to Fix It:
Found a Blown rear washer fuse number 81 in the under hood fuse box {pain to get at} have to get one Micro 2 not easy to find probably on Amazon Let you know if that fixes it,
TheCornerKing
Trent
Murrieta, CA
2023 BS Badlands, 2022 Tesla M3P
to ChatGPT:
How to Fix It:
I like where your head is at! Don’t even need to think or ask questions to get flamed in the comments anymore. Just ask AI bot and you get your answer. I use it for work every day and we are training our own AI for mundane work tasks at work and home.
mbeckm
PA USA
Yes, if everyone used AI first there would probably be a lot less chatter/clutter in these Threads, on Reddit, Facebook, etc. However, in this case it looks like the OPs problem might be a fuse and the ChatGPT missed it. If the fuse is the problem I can tell ChatGPT that the OP is smarter than it is! Of course, then ChatGPT would remember that, thank us profusely, and add the fuse to it's list of answers so the next person with the same question would get better results. Hope to hear back from the OP.
Time to start staying in bed and let AI take over.
